theres not much to fitting them, just make sure you have a full day to devote to putting them on and taking them off. the sawzall made short work of the bedsides.
![]() ![]() "we are just going to have to build it so that the weakest link is... nothing." haha |
not to thread jack, but are u still doing your solid axle swap ? |
Not at the moment... All of my sas stuff is under mudpunishers truck. He bought everything i had. I just purchased all of the front end parts to convert mine to 4wd... I will be locked front and rear and with some creativity i plan on running 35's
Just because I'm 2wd doesn't mean I'm handicap, it's all the other reasons. Future mods: Tune suspension and get 4wd conversion finished. |
Your truck looks horrible, you should return it to stock.
hahahahahaahahaha
West Covina Nissan 205 N. Citrus St. West Covina CA www.thenismoshop.com 626-732-1000 x6375
What size tubing did u use for the links? 2 OD / 1.5 ID?
what did u use for brackets and flex joints? |
i forget what its called, but the links are 2" wide. the strongest stuff you can buy. im pretty sure they are .25" wall.
brackets from RuffStuffSpecialties.com - Off-Road Fabrication Parts ball joints from Ballistic Fabrication - Manufacturers of Precision Offroad Fabrication Supplies heims/bungs from Rockkrawler 4 link kit, bearing, heim joints, heims, joint, jam nut, supply, rod ends
the evolution:
this was about a week after i bought it. a few months later i registered on 4x4parts.com, and about a month after that, i went wheeling with the guys that would eventually sas my truck. ![]() new rims and bfg tires! ![]() custom light bar/clevis mounts ![]() ![]() theking made me some sliders ![]() fenders/headlights ![]() intake ![]() exhaust ![]() bumper ![]() winch ![]() beginnings of the solidification: ![]() ![]() ![]() ![]() ![]() yay, front was done. ![]() yay, rear was done. ![]() yay, cool truck- "done." ![]() ![]()
