  #301 (permalink)
Old 04-10-2008, 10:58 AM
Banned
Originally Posted by roastbeef View Post
we have to get the rear spring rate dialed in. we are also going to do hydro bumpstops up front. theres not much room up there, so we are going to have to integrate them into the frame.
i might run 37's when these xterrains are spent. i will definately be going with a tire with a stronger side wall. i really want to try a set of bfg cralwer t/a's. i have heard lots of good things about those.
Remember that tires usually don't measure what they say except for swampers, other tires are normally smaller than whats said after their mounted, plus clearance issues are usually solved with a Sawszall or a "Hot wrench"
You've gone this far, you can't skimp on anything now !!!
I'll have to rescend a previous statement , your truck definately will out flex my toyota ... You've done well ...keep up the good work !!!
"Keep the rubber side down"
  #302 (permalink)
Old 04-10-2008, 08:28 PM
roastbeef's Avatar
haha thanks. im going to try not to get too crazy. i don't want to lay her on her side untill i get the exo on.
im pretty sure the axles will come close to 90* of combined flex. we are going to run a limit strap in the rear, but it is not going to affect the articulation, only the downtravel of the entire axle.
  #303 (permalink)
Old 04-12-2008, 02:02 PM
06_footy's Avatar
mickey thompson baja claw's are good 2
other ? how much lift are u looking at as of right now.....
myspace.com/unawareconception
2006 crewcab SE 2wd
  #304 (permalink)
Old 04-12-2008, 07:35 PM
roastbeef's Avatar
i don't know how much lift i have. if someone with a stock 1st gen wants to measure the distance between the ground and the bottom of the frame i can measure and subtract the difference.
the baja claws are schweet. very deep side lugs.
  #305 (permalink)
Old 04-13-2008, 09:15 AM
houdini's Avatar
what is your measurement RB? i am at 25.5"
http://www.noas4x4club.com/
http://www.encxc.org
  #306 (permalink)
Old 04-13-2008, 07:28 PM
dhmachine86's Avatar
you going to cut out those shacklemounts off?
Black '02 XE CC LB 4x4. MANual. 3" Calmini SL. Rubber-TBD.
  #307 (permalink)
Old 04-13-2008, 07:35 PM
bake's Avatar
When are you going to do the rear fenders?
  #308 (permalink)
Old 04-13-2008, 11:27 PM
roastbeef's Avatar
i am at 21.5" under the frame, and 11" under the front diff.
my rear fenders are going to be on soon, my bud is painting them. we are going to torch the shackles off soon. haha.
  #309 (permalink)
Old 04-23-2008, 08:49 PM
roastbeef's Avatar
completed the crossmember/spare carrier today. came out great.
oh yea, the rear glass flares are on too. before anyone says anything, i plan on an exo so they don't get ripped off.
  #310 (permalink)
Old 04-23-2008, 09:11 PM
Shinjari's Avatar
man that looks freakin sweet....i wish they made fenders like that for the 2nd gens....i'd be alllll over that.
06 Storm Grey LE CC 4x2
FORMER Mods: TITAN Swap, Sway-a-Way COs, CST 4" Spindles, PRG Shackles and AAL, Bilstein 5125s, NISMO CAI, Custom Exhaust, 2* advance, Procomp 7089's and 285/70/17 BFG A/T's
Want to learn how to install your PRG spacers and Deavers? Click here
HTML code is On
