Old 04-22-2008, 04:36 PM
Re-gearing necessary?
I plan on getting a 2008 KC SE I4 4x2 this summer and I want to put a leveling kit on it so I can fit 33" All-Terrains on it. I'm curious what effects that will have on the drivetrain. I've read a little bit about re-gearing for bigger tires since you effectively lose power but I'm curious if anyone has any information on the effects of not re-gearing. Will I get better or worse gas mileage? I know it puts undue stress on the tranny in uphill situations where you need power. My truck will almost never see off-road situations and all this modification is for asthetics only. Anyone feel like helping? I haven't been able to find a gearing kit for the 2005+ Frontiers but I did find a calculator and it suggested going from the stock 30's to 33's means I need to re-gear to 4.10ish
"My karma ran over your dogma."
Shift_Paradigm
Old 04-22-2008, 05:20 PM
Inyourface1650's Avatar
There are no gears out anyway, so you're stuck with what ya brung.
Originally Posted by blackwidowoffroad.com
Thanks inyourface for being the di$* that you are, we are all better for it, and we do appreciate you!
Oh Inyourface is an a$$hole, but an informative one - Which is the only reason CF hasn't banned him yet
1994 Pathfinder 4x4. Emerald Black. AC 3 inch suspension lift, 2 inch body lift, Upgraded Steering, Rusty Shrockworks Sliders, Rancho 9000 adjustable shocks, 33x10.5R16 BFG A/Ts, Roof rack, lights, dual gas cans, 1500watt inverter, some random amp, 110 amp alternator, Flowmaster 50 Exhaust, Cheapo CAI.
NEED MORE POWAAAAH!!!!
0-60 time...well I got burned by a Mercedes 300SD....
I love going off roading when ever I can. It's exciting to drive on the lawn and the dirt roads......... - RidgeLine Owner.
Old 04-22-2008, 05:36 PM
Or you can do an axle swap but on an 08', it would void part of the warranty and cost a pretty penny. Maybe gears will be out in a couple of years.
Old 04-22-2008, 05:39 PM
khmaiaznboi89's Avatar
you should be fine but your speedo will be of like 5 mph or something around there
SILVER 05 Nismo Crew Cab (first owner on only 36k)
+ STILLEN High-Flow Intake
+ Yellow fogs
+ WRP TBS
White 05 SE Crew Cab(my uncle leaves it at my house)
+ my old K&N drop in Filter
hopefully a gc8 impreza (soon)
Old 04-22-2008, 05:41 PM
Not to mention a absolute dog. 154HP and 33s?!
Old 04-22-2008, 06:14 PM
cctmobiledetail's Avatar
If your going to lift a truck and want a regear and want the reliability of a Nissan, buy a Toyota instead, because there are tons of axle, ring and pinion + hundreds of more mods out there for yotas than Nissans. I bought my nissan for to keep stock and use as my company truck, I have an old yota for wheelin' ...
Old 04-22-2008, 07:02 PM
Maxvdub62's Avatar
I got 4.10's
Old 04-22-2008, 07:20 PM
Originally Posted by Maxvdub62 View Post
I got 4.10's
Where? A quick look at the chart at Superior Axle and Gear suggests that to get back to normal RPMs I'd need to regear to 4.1's... However, even if I stayed with the stock 3.7's I'd still be within operating range. I would just be at lower RPMs and therefore get better gas mileage but less power. Since most of the driving will be flat highway or city driving I'm not too worried about the loss of power but I don't want to blow the transmission. I can't believe they don't have gears yet...
Shift_Paradigm
Old 04-22-2008, 07:32 PM
I wonder if they use 3.7's in the (four banger) SE's. Cause XE's have 3.7's with the little tires, and the (four banger) SE's I think come with the same size tires as the 6cylinder guys.....
I woulda thought nissan would have re-geared it to make up for the tire size.
Old 04-22-2008, 07:53 PM
Its true, the XE's come with 235/75R15's (28.8 inches) and both the 4-cyl and 6-cyl SE's come with 265/70R16's (30.6 inches). I found this website Nissan Frontier Specifications and Capacities that details the final gear ratios. According to this, my SE would be running a 3.133:1 ratio since its automatic transmission. With help from the chart from Superior Axle and Gear that shows I'm already lacking power, right? Sheesh this is confusing...
Shift_Paradigm
HTML code is On
