Pinion depth - Nissan Frontier Forum
 3Likes
post #1 of 12 (permalink) Old 03-11-2017, 02:02 PM Thread Starter
whistler's Avatar
Quoted: 495 Post(s)
Pinion depth
Curious if anybody has measured differential pinion depth? What did you use to measure it?Don't want to spend a lot for measuring tool. Maybe make a tool using depth mic.
Have everything else I need to set- up new gearing for my differentials.
nfloyd77 likes this.
whistler is offline
nfloyd77 (03-12-2017)
post #2 of 12 (permalink) Old 03-12-2017, 12:00 AM Thread Starter
whistler's Avatar
Quoted: 495 Post(s)
I figured out how I am going to do it.Just need to make the tool.
The pinion gear is marked 1.570, that is the depth I need to be able to measure.
I think I pretty much have everything to do the job.
whistler is offline
post #3 of 12 (permalink) Old 05-19-2017, 12:57 PM
Quoted: 10 Post(s)
What did you end up doing? Have you found any other info? I have experience setting up ford 8.8" differentials using Ford's pinion depth tool but I'm not sure how to properly do it on Nissan differentials.
2016 SV CC 4x4
nfloyd77 is offline
post #4 of 12 (permalink) Old 05-19-2017, 11:22 PM Thread Starter
whistler's Avatar
Quoted: 495 Post(s)
Still have not started on the differential. Still plan on making a tool that will line up to the centerline of the axle tube. I will use a Depth mic to measure the pinion depth. Don't think it will be a problem.
whistler is offline
post #5 of 12 (permalink) Old 05-20-2017, 11:12 AM
Quoted: 10 Post(s)
The Ford tools have a solid cylinder that is machines to the o.d. of the carrier bearing races that you install in place of the carrier and bearings. There is another tool that installs in place of the pinion gear and you slide different shims between the two (like using the shims as feeler gauges) until you find the right shim. It could be done as you said by having flats machines onto two sides of the cylinder and a hole for the depth mic to insert through. I don't have access to a machine shop but I think there could be a small market for these.
Sent from my iPhone using Tapatalk Pro
2016 SV CC 4x4
nfloyd77 is offline
post #6 of 12 (permalink) Old 05-20-2017, 08:26 PM Thread Starter
whistler's Avatar
Quoted: 495 Post(s)
The market would be too small to be profitable. How many people here on this site would even attempt to do their own differentials?Not just the ability but having the equipment. Not many people even know how to read a depth mic.
Anybody with these skills such as yourself would be able to figure it out.
Compared to what I did in my 30 plus years as a machinist(also spacecraft assembly, intergration and test, tooling, composites etc.)
like I said it should not be a problem.
whistler is offline
AndysLog (05-22-2017)
post #7 of 12 (permalink) Old 05-22-2017, 12:40 PM
Nissan4Life's Avatar
Quoted: 447 Post(s)
Is the pinon depth a trial and error thing. Install initially by a measured depth, then paint the gear teeth. Run. Look at pattern in the paint. Pull pinon, add or subtract shims. Rinse repeat till pattern in paint is right.
I remember helping a friend set up gears in his truck. What a PITA operation that took several nights.
06 KC NISMO 4x4 6sp
Nissan4Life is offline
post #8 of 12 (permalink) Old 05-22-2017, 04:14 PM
Quoted: 10 Post(s)
I believe that's the way most DIYers do it and there's nothing wrong with it except for the time involved. If you have a proper way to measure pinion depth, it is a much quicker process and the only PITA is crushing the crush sleeve, especially if you're working under the vehicle on jack stands and don't have a real strong impact wrench.
2016 SV CC 4x4
nfloyd77 is offline
post #9 of 12 (permalink) Old 05-22-2017, 06:48 PM Thread Starter
whistler's Avatar
Quoted: 495 Post(s)
The pinion depth alone will not give the correct lash.
Side bearing adjustment also must be accounted for.
When I installed the "Trutrac" the pinion depth remained unchanged but still had to adjust the side bearings.
ID:	245833   Click image for larger version
whistler is offline
post #10 of 12 (permalink) Old 05-22-2017, 07:02 PM
Quoted: 10 Post(s)
Yes but backlash can be measured, as shown in your post, with a dial indicator. Dial indicators are more available than pinion depth tools, especially oem pinion depth tools.
2016 SV CC 4x4
nfloyd77 is offline
HTML code is On
