  #41 (permalink)
Old 12-31-2007, 12:39 AM
Inyourface1650's Avatar
ooooh NP205. That wont break.....ever....damn high low range though.
I drive an Altima...with a CB antenna
I love going off roading when ever I can. It's exciting to drive on the lawn and the dirt roads......... - RidgeLine Owner.
2002 Altima 2.5S - In service
2008 Altima 2.5S - Gone
2007 KC 4x4 6M NISMO - Gone
2007 KC 4x4 5A SE - In service
2005 KC 4x2 6M SE - Gone
2005 Xterra 4x4 SE - Gone
2002 CC 4x2 SE - Gone
  #42 (permalink)
Old 12-31-2007, 04:16 AM
sexy6chick's Avatar
Originally Posted by mudpunisher
heres the axle build up so far for fronty2wd
looks damn good to me! keep up the good work boys.
  #43 (permalink)
Old 12-31-2007, 08:51 AM
fronty2wd's Avatar
i want strength thats for sure. I kinda like the not so low range though because i will be able to turn big tires in the mud... I do live in Florida so most of my wheeling consist of deep nasty mud.
Future mods: Get axle mounted and ready for fall noas ure run!
  #44 (permalink)
Old 01-02-2008, 11:28 PM
BroncoDude's Avatar
Mud is some cool stuff. I've seen a guy run a 454 and 44" super swampers with dana 18 t-case clocked 90 degrees downward from the frame. It's amazing what you can get away with when you have no traction and some 6.72 gears in the diff.
Bronco-351W F4TE roller block OBD II ECM, E4OD, Borg Warner 1356, TTB D44, Ford 8.8, open/open 3.55's and a partridge and a pear tree.
  #45 (permalink)
Old 06-22-2008, 03:52 PM
fronty2wd's Avatar
Well the swap is back on with slightly different components. I am using a hp 44 out of a 79 f-150 and a 9" for the rear. I plan on using the radius arms up front with jeep tj springs. Here are some pics of the stuff i just got from ballistic fab. Everything is made from 1/4" a50 plate steel so i don't think will be an issue with these parts.
Trackbar mount and bushing
Me and mudpunisher got the coil buckets welded up. These turned out very nice and will have about 5 inches of ride height adjustment
And some misc. stuff ( coil retainers, other trac bar bushing, etc.)
  #46 (permalink)
Old 06-22-2008, 06:16 PM
Johnnyman88's Avatar
any estimated time it will be close to finish? not too be like rushing you but just a ball park time would be good.
Calmini Kit W/ PRG Upgrades
TC UCA's
AC Body lift
WRP GK
JBA Catbak Sys. & AEM CAI
  #47 (permalink)
Old 06-22-2008, 09:22 PM
fronty2wd's Avatar
I already committed to the fall run at ure so i would say no later than the second week of september but the plan is set for the swap to start on the 8th of august and i'm taking that whole following week off of work to do the swap so i should be able to get it done in that 9 day period.
  #48 (permalink)
Old 06-24-2008, 11:06 AM
fronty2wd's Avatar
More pictures to come later this evening of the progress on the axle.
  #49 (permalink)
Old 06-29-2008, 11:10 AM
fronty2wd's Avatar
Sorry about the lack of updates. THe weather here has been horrible in the afternoons so i havn't been able to do much. Howerver i will get some more pictures tonight as the 5 to 6 lug conversion should be complete
  #50 (permalink)
Old 07-07-2008, 07:48 PM
fronty2wd's Avatar
6 lug conversion complete.
Note to all who ever have to adjust wheel bearings... NEVER EVER stick your fingers in the veins of the rotor and spin the rotor to check bearing tightness... Some times the brake caliper mount can get in the way.
Once i figure out the placement for the track bar mount and get it welded in place i will clean up the wole axle a little better and give it a fresh coat of paint.
« gears | - »
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
fronty2wd
HTML code is On
