m226 chromoly axle shafts - Page 2 - Nissan Frontier / Navara Forum
Go Back   Nissan Frontier / Navara Forum > Mods and Technical Discussions > Drivetrain Discussions
Old 01-28-2013, 09:58 PM
westracing01's Avatar
Feedback Score: 4 reviews
Send a message via AIM to westracing01
For those interested in this project, more detailed info can be found in thenewx thread on this subject.
2009 Titan Swapped PRO-4X KC 4x4 6spd...
See my Build Thread for mod list and pics...
"A little government and a little luck are necessary in life, but only a fool trusts either of them."
The words "Titan Swap, cheap, easy, M205, re-gear, quick, coilovers" are not to be spoken in the same sentence.
Old 01-29-2013, 11:08 AM
06blackse's Avatar
Is there a huge benefit (that sounds stupid I know) running on the stock e locker, would I need to change my e locker to an arb or something else to reap the real benefit? 370 isn't bad for chromoly shafts
Sent from AutoGuide.com App
Current Collection:
09 Honda Civic SI Sedan (Wife's car again/track car on weekends now lol)
10 Nissan Frontier Pro4X Crew Cab
(Calmini 5" Lift with Sway A Way 2.5's, 2" PRG Deaver, AFE Stage 2 Intake system, Banks Monster Exhaust system, Superchips tuned, Pro Comp 8089 Wheels, 285/75/16 Goodyear Duratrac, Trail Ridge Offroad Custom Sliders)
VOTE FOR ME FOR TOTM
http://www.clubfrontier.org/forums/f...k-month-88322/
Old 01-29-2013, 12:13 PM
kbwhipple's Avatar
460$ he said needed more machining.
Sent from AutoGuide.com Free App
Old 01-29-2013, 12:17 PM
06blackse's Avatar
Still not too bad, I spent a lot more than that on my Honda civic ones so it would handle 600 HP
Current Collection:
Old 01-29-2013, 01:47 PM
06 (^^^) to answer your question, no, you would not need to buy a new carrier to run the Chromo shafts. You would have to buy new bearings and seals though and press off the tone ring on your OEM shafts to install on the new ones, along with the bearing cage.
Or, buy new tone rings, bearing, seals and bearing cage and use the OEM axles as a set of trail spares.
As for benefit, this is really for peace of mind. The stock axles are good, but going to a 35" tire or larger you'll want the knowledge that the equipment under your rig is as tough as possible. Personally, I'm putting an ARB in along with the chromo axles but that isn't expressly needed.
We still need to find a side gear to send Moser to make sure the splines on the end will be machined correctly.
Old 01-29-2013, 07:28 PM
kbwhipple's Avatar
In this he said that the extra cost was to keep the tone ring? So it will come with a new chromoly one I am assuming?
Old 01-30-2013, 08:59 AM
No.
Here's the bottom line. The axles will be bare axles, no tone ring, no bearings, no bearing cage, no bearing retainer ring. Just the axle. The purchaser will be responsible for all the associated parts that go on the axle to install it.
All the stuff I mentioned is pressed on the axle. See this for further detail:
I have to call Shane this morning and ask a couple of questions. Might have located a side gear but it'll have to wait until next week to get it sent to them.
Old 01-30-2013, 06:13 PM
kbwhipple's Avatar
Breaks my heart there not actually chrom. But ok on the tone ring.
  #19 (permalink)
Old 01-31-2013, 12:58 PM
Breaks mine too. Dunno where we're going from here, but I think a lot of interest went south since they're not really chromoly. We'll see.
If this project dies then I want to get Aaron his axles back. After that, I'll see if I can score a set of my own and see what I can come up with. I don't want to have other guys parts floating out in the wind.
  #20 (permalink)
Old 01-31-2013, 01:10 PM
kbwhipple's Avatar
Guess so... Dang and I was holding out... Axel seals started leaking and saw this and was gonna do it all at once. Yeah I think it did go south not being actual chrom.
HTML code is On
