Old 09-08-2008, 04:09 PM
zhampton21's Avatar
Locking Rear Diffs
I searched around, and couldn't find an exact answer to my question, so I apologize if this has already been discussed.
Are there any after market rear diff lockers out there that allow the LSD to remain when not engaged, or do all of the lockers force the rear diff to become open when not engaged?
Also, anyone throw any recommendations out there for rear lockers, both auto and manual (If there are both)?
I originally was planning to purchase a NISMO for th rear diff locker, but go figure there were none to be found within 2 states of Arizona. I had to go for the SE, which is essentially the same, without the locker, skids, and stickers.
Thanks.
2008 SE 4x4 KC A/T 4.0 Smoke Gray
Mods: Bass Pro Sticker
Plans: PRG 4x4 3" suspension lift kit, BF Goodies AT265/75R16, Pro Comp 1059 16"x8" wheels, K&N FIPK, Flowmaster Exhaust system, Shrockworks Skids & sliders, Westin Bull Bar, PIAA fog and superwhite driving lights.
All this to be finished soon.
Old 09-08-2008, 04:16 PM
bigdog's Avatar
There are currently no aftermarket lockers for the Frontier at all. ARB may be making an announcement very soon. But most beleive that it will be for the M226 Diff and not the C200, but only time will tell. We may soon get one for the front though.
2006 SE CC 4x4 A/T:
The Following User Says Thank You to bigdog For This Useful Post:
zhampton21 (09-08-2008)
Old 09-08-2008, 04:36 PM
Banned
ARB will be making a locker for the c200 I believe. The m226 has the e-locker and true trac option, so I can't see the market for a m226 locker
The Following User Says Thank You to jimmyslade For This Useful Post:
Old 09-08-2008, 04:45 PM
mike's Avatar
The locker from ARB that should be out in a few weeks is for the M226 diff.
ARB is an australian company and all Navara have the M226 diff.
The Following User Says Thank You to mike For This Useful Post:
Old 09-08-2008, 04:47 PM
penski61's Avatar
c200 locker will be a long ways out or may not come out at all , atleast thats what i was told by ARB when i sent them my carrier for reasearch
The Following User Says Thank You to penski61 For This Useful Post:
Old 09-08-2008, 04:53 PM
bigdog's Avatar
Well, that may be wishful thinking. If you look at their website they seem to be planning of the M226
NISSAN
Front - 1986 on R180A,4 cyl. 27.8 (1.09") 27 All NA
......................R200A,6 cyl. 30.4 (1.20") 29 All RD107(4)
Rear - 1986 on H233B,31 spline, 6 cyl. 32.0 (1.26") 31 All RD136 (3,4)
.....................H233B,33 spline, 6 cyl. 33.3 (1.31") 33 All RD135 (3)
------ 1986-97 C200,29 spline, 4 cyl. 30.4 (1.20") 29 All RD107 (1,3,4)
------ 2002-05 C200,31 spline 32.0 (1.26") 31 All RD106 (3,4)
------ 2005 on R230,33 spline,IRS 33.3 (1.31") 33 3.54 & UP RD137(6)
.....................M226,32 spline,10 bolt RG 32 All RD149 (5)
1 Only suitable for differentials with 12mm crown wheel bolts.
2 No application for leaf sprung cab chassis vehicles with 34 spline axle shafts.
3 Refer to dealer or check spline count to determine axle type.
RD135 & RD136 require the higher rated 50mm ID carrier bearing (Timken #32010X - ARB #160116).
4 Floating thrust block(s) are included but should ONLY be installed on semi-floating axle assemblies. Refer to installation guide.
5 Available late 2008.
6 RD137 does not suit ratio up to 3.36:1 due to RG offset.
http://dedq15.mindfly.com/uploads/PD...kerAppsUSA.pdf
notice that it is the M226 that they list as Available late 2008 and there is no mention of the 05+ C200
2006 SE CC 4x4 A/T:
Old 09-08-2008, 06:10 PM
zhampton21's Avatar
I noticed 4wheelparts.com has some Dana 44 axles with the locking diffs but they are pretty expensive. I'd love to upgrade, but is it worth the $2500 to do so? Is the axle really that much better?
Old 09-08-2008, 06:14 PM
mike's Avatar
Now that we have clearify that the locker from ARB is for the M226.
Automotive Customizers is working on a locker but I don't know if it is for the M226 or the C200.
Old 09-08-2008, 07:56 PM
Mainerunr's Avatar
it's about time, I emailed ARB over 2 years ago about a locker for the M226 (some of you seem to be forgetting that Titans use the M226, there is PLENTY of market for it). They said then that it was on the list, they just did not know when.
Old 09-08-2008, 10:37 PM
Hopefully ARB is really going to cover the m226 and then AC is going to realize this and cover the c200. This would be the best for both worlds and they would not be competiting against eachother.
HTML code is On
