Old 06-27-2008, 08:00 AM
Locking Hubs Stuck...Help!
I recently purchased a 1998 2.4 4wd and the locking hubs are stuck in the free position. I'm guessing they haven't been serviced/used in awhile. When I say stuck, I mean I can't even move the switch to engage them. Any suggestions? Will liquid wrench or something similar free them up? Also, can I free up the switch by taking the wheel off and pulling the hub assembly apart? Never done that, but I'm willing to give it a go. Thanks for the help.
1998 2.4 4wd Stock w/ topper
Michigan
Old 06-27-2008, 09:36 AM
I have never done a hub swap or hub work, but i have seen it done and can say that it is a straight forward procedure. Do some searching on the net and i am sure you can find some instructions about it. Or call a 4x4 parts supplier and ask them. Also mannual hubs are generally an inexpensive fix.
2007 Crew Cab SE 4X4
Old 06-27-2008, 11:12 AM
fronty2wd's Avatar
What kind of hubs do you have?
Future mods: Get axle mounted and ready for fall noas ure run!
Old 06-28-2008, 10:28 AM
houdini's Avatar
just pull them apart, clean and grease them. i doubt you will have to pull the wheel to get them off.
good luck!
Old 07-01-2008, 08:39 AM
Thanks guys. I'll let you know what happes. Also, they are just the stock locking hubs.
Michigan
Old 08-30-2008, 05:47 AM
Did you manage to fix your hubs? If so how? I have the same problem except mine are stuck in the locked position.
Houdini: How would you be able to take them apart without taking the wheel off? This is my first Nissan I have always had rangers and on them you had to pull the wheel to get the hub off.
Thanks
HTML code is On
