*HELP* Rear End Clunk/Whine *HELP* - Nissan Frontier Forum
post #1 of 7 (permalink) Old 05-19-2017, 01:06 PM Thread Starter
frontierfreak7's Avatar
Quoted: 62 Post(s)
Need help I have a clunk under deceleration and a rattling under acceleration. I have a video where you can here the rattle and then the clunk, this was taken about 50mph and dropping to 40mph does it both when in gear decelerating and when I neutral decelerating. I have an m226 with an e locker, any input is appreciated I did change the u joints last night and it's still clunking I can feel it in the shifter.
https://youtu.be/heZ8DMiYsSc
Titan swap w/ 2.5 ext resi SAWS, 2.0 Air bumps, Deaver racepack, Radflo external resi rear shocks, and much much more
frontierfreak7 is offline
post #2 of 7 (permalink) Old 05-19-2017, 01:38 PM
AndysLog's Avatar
Quoted: 855 Post(s)
Feedback Score: 9 reviews
take a video under your truck if you can.
also, take it out to a large grassy field, toss the elocker on and take it up to higher speeds and see if the noise persists.
if the noise goes away, you need a new carrier.
it sounds vaguely familiar to my elocker when it was having issues. trutrac for the win.
could also be a bearing, you can help test by loading them by turning while the noise is going.
AndysLog is offline
post #3 of 7 (permalink) Old 05-19-2017, 01:41 PM Thread Starter
Quoted: 62 Post(s)
Thanks man, I'll try and I can take a video under the truck I'll strap a camera underneath. Don't have any big grassy field to test the locker straight line with no turning on the pavement would do the trick?
post #4 of 7 (permalink) Old 05-19-2017, 03:57 PM
AndysLog's Avatar
Quoted: 855 Post(s)
the only reason i mentioned grass was because your current setup from what i remember you were running some heavy tires. elocker is kinda weak for what we all use it for.
not saying i think you will have an issue, just trying to be safety steve haha, but im sure it would be fine.
my elocker ended up being the actual mechanism that locked that was making the clunk noise i hear in your video. i think i heard a secondary im not familiar with but if you have a under the truck video i may be able to hear better.
but when i took my elocker apart, the spider gears were perfect.
AndysLog is offline
post #5 of 7 (permalink) Old 05-19-2017, 04:12 PM Thread Starter
Quoted: 62 Post(s)
So when you took the e locker out and put in the trutrac the noise was gone? Also does the trutrac use the long and short shafts?
post #6 of 7 (permalink) Old 05-19-2017, 04:17 PM
AndysLog's Avatar
Quoted: 855 Post(s)
correct. i replaced the whole carrier-elocker.
now this will take me a minute to remember exactly what i did.
i believe the passenger side shaft is just a hair too long, and the splines bottom out on the input to the trutrac. i swapped my passenger side axle for a non elocker passenger side axle and the contact patch was hovering right at 50%
i think if you had a decent machine shop you trusted, could just extend the splines on your existing axle about an inch or so. this would be about the same price i think, but you contact patch will be 100%
im not saying your elocker mechanism is toast like mine was, but it sounds really similar to the noise mine made.
i also thought it was u joints originally. i swapped all 4 before i finally mounted a camera under the truck and could pinpoint the carrier making the noise. from there i pulled the cover and looked and all looked fine.
tossed the locker on in my yard and got up to speed and it was whisper quiet. that was enough evidence for me to order the trutrac that night.
AndysLog is offline
post #7 of 7 (permalink) Old 05-19-2017, 08:48 PM Thread Starter
Quoted: 62 Post(s)
Hey man send me a text I lost your number took video underneath I can send you
HTML code is On
