help... diff lock, vdc off lights on why? - Nissan Frontier Forum
post #1 of 18 (permalink) Old 02-02-2011, 11:03 PM Thread Starter
andyvr4's Avatar
i was driving home today and all of a sudden my diff lock light came on steady, and the vdc off light came on . A little bit after the diff lock light went out and the abs and slip light came on w/ the vdc off light still on. the truck didnt do anything i didnt do anything and im not sure what to do. also when i first start the truck now it reapeats everything over again. i tried pushing the vdc off button it does nothing. and right when i start it i hit the diff lock button and it goes straight to the abs, slip and vdc off lights being on. im stumped. thanks ahead of time for the help.
andyvr4 is offline
post #2 of 18 (permalink) Old 02-03-2011, 12:27 AM
MESOGLEA's Avatar
Quoted: 54 Post(s)
Check connectors on the ABS sensors at the wheels. Try disconnecting the battery for 30 minutes. It will go through a BIT (built in test) and calibrate.
I think I'm finally done with the modifications......
https://www.youtube.com/channel/UC-m...w_UuTmJmkLS8cg
MESOGLEA is offline
post #3 of 18 (permalink) Old 02-03-2011, 01:02 AM Thread Starter
andyvr4's Avatar
where are those located
andyvr4 is offline
post #4 of 18 (permalink) Old 02-03-2011, 01:28 AM
MESOGLEA's Avatar
Quoted: 54 Post(s)
Near the brake calipers. Have you a service manual?
MESOGLEA is offline
post #5 of 18 (permalink) Old 02-03-2011, 01:34 AM Thread Starter
andyvr4's Avatar
yup checked they are tight at the plugs
andyvr4 is offline
post #6 of 18 (permalink) Old 02-03-2011, 11:36 AM
MESOGLEA's Avatar
Quoted: 54 Post(s)
I cleaned the battery terminals on mine. The VDC light came on an was on for 20 miles. I disconnected the battery for over 20 minutes. I didnt even back out of the driveway and the VDC light went out.
Not saying that this is your problem but worth a try.
MESOGLEA is offline
post #7 of 18 (permalink) Old 02-03-2011, 11:46 AM
sledneck's Avatar
Feedback Score: 3 reviews
I had the same problem. The dealer said I had a bad "wheel angle sensor"
fixed under warranty.
2005 NISMO KC 4X4 - Rust In Peace
2008 NISMO KC 4X4
20% Tints-Ventshades- OEM Hood Protector-Truxedo LoPro-UWS custom box-Airaid intake-WRP ground kit-PRG 2" lift with spacers and AAL-285/75/R16 BFG AT/KO-Polks all the way around-SuperChips Tuned-more to come
sledneck is offline
post #8 of 18 (permalink) Old 02-03-2011, 12:13 PM
MESOGLEA's Avatar
Quoted: 54 Post(s)
wheel angle sensor like in steering the column?
MESOGLEA is offline
post #9 of 18 (permalink) Old 02-03-2011, 04:40 PM Thread Starter
andyvr4's Avatar
how could I test that. the reverse and dc light going out I've done that before but its not that. any other suggestions ? I drove today still lights are on but no acting up ? I even left the posative cable to the battery off over night and still same
andyvr4 is offline
post #10 of 18 (permalink) Old 02-03-2011, 04:52 PM
MESOGLEA's Avatar
Quoted: 54 Post(s)
Go see the dealer.
What year is your your ride?
MESOGLEA is offline
HTML code is On
