sorry penski1 if this isnt a contribution to the thread---more of question about your post---but your saying and as we all know the gears for m226 were shaved down to fit with locker right? and new gears probably wont fit correctly unless they made gears to fit m226 with locker right?
CALMINI sucks! ![]() ![]() ![]() |
sorry if this isnt a contribution but since they dont have enough room to shim back and forth. I have been wondering if it's possible to get a drill-bit and smooth down the outer-insides around the gears so they have more play. By taking out the gears and or taking a rubber hammer and a metaL sheet formed to the inside of your m226 you could lighty hammer the the inside to maybe a qauter of an inch wider then like toyniss said and possibly shave down slightly soem of the edges you deem fit.
What he's saying 3.69 is tight in there, so any bigger gears are going to have problems fitting. His 3.69's fit fine.
i think your replying to toyniss's post not mine oops Last edited by 06_footy : 07-27-2008 at 11:02 PM. |
well we already knew the gears would fit the front diff since all the 2nd gens have the same front diff!
thanks penski1 for again making and showing us one more possible upgrade(s) for those that may want to switch from 3.35 or whatever up to 3.69's. im sure bigger gears are going to have a tough time fitting locker diff hence the reason 3.69's or even 3.53's for that matter were shaved down to fit with locker, also the reason there probably arent any gears out for these trucks yet! looks like we may be stuck with what we got. either swap axles or do the atlasII tcase swap. cause regearing for bigger tires may be out of the question. i dont know much about gears, but are lower ratio gears bigger in diameter than higher ratio? penski1 you could probably answer that from looking at the difference of the 3.69's to 3.53's?
CALMINI sucks! ![]() ![]() ![]() Last edited by toyniss : 07-27-2008 at 11:47 PM. Reason: Automerged Doublepost |
its not really the size of the ring gear thats gonna be the big issue its the pinion size , like i said before you have no room to move the carrier side to side , so im guessing if the pinion gear is bigger you would need to shim the carrier over more to one side so they mesh well , if you cant move the carrier your out of luck , but hey hopefully im wrong in thinking thats how u have to setup the gears , and theres no way im shaving or drilling anything in there
thanks for your input. only time will tell, but what you just said may be the reason there arent gears out yet, it could be such a tight fit with our carrier that not feasible to get anything in there thats bigger if thats whats needed to get lower ratio gears. hopefully they will figure something out someday, or we'll all be doing axle/sas'd swaps, or buying a different rig for wheeling.
well i went from 3.35 to 3.69 no difference in size just once less tooth on the 3.35 than 3.69 , but i would imagine there is a diff in size between 3.69 and the lowest option from superior 4.56 |
yea, its not really a size thing, its all about the tooth count on the drive gear and on the corresponding drive pinion. For example 49/12, 48/13, 47/16, 47/15, 47/14 all could be the same size ring but produce differant gear ratios.
