Old 07-02-2008, 12:35 AM
penski61's Avatar
man that would be awesome nizmut let me know when your ready
Old 07-02-2008, 04:02 AM
Maxvdub62's Avatar
Is that a 9" I see?
Old 07-02-2008, 04:21 AM
Inyourface1650's Avatar
I see a nice purdy set of pink work lights?
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
ONAZ
Old 07-02-2008, 08:58 AM
nizmut's Avatar
what the hey they were free
Originally Posted by Maxvdub62 View Post
Is that a 9" I see?
yeah and if you look close you will see a spare 3rd member.
Also another nismo rear with a spun housing, I need to pull the axles on that and replace my bent one.
axle bearing, seal and ring spacer cost as much as I paid for the 9"
Old 07-04-2008, 08:30 PM
nizmut's Avatar
Hey penski, Curry will not fix the tube on that other m226 so here is what I can do.
I need the axles out of it to get rid of my bent one. I can cut the tubes off it and ship you the center. Take what you want out of it. It is a 06 low mileage, with locker. So you get a spare locker. Gears that are a matched set at 3.69 to1, and a spare carrier. Or if you can find someone to re weld the tube I can send you the whole thing.
Old 07-04-2008, 09:55 PM
penski61's Avatar
so just to make sure this was out of a Kc nismo 4x4 manual or Cc se 4x4 manual , how much you want for just the center ?
Old 07-04-2008, 10:46 PM
nizmut's Avatar
shipping and 50 for my troubles. I will pull the cover and stuff the tubes before I cut them to keep the center clean.
It is out of a 06 KC 6sp nismo.
Old 07-04-2008, 10:55 PM
06_footy's Avatar
Hey Nizmut im guessing you got that out of that ranger right ? If so thats a pretty good idea.
myspace.com/unawareconception
2006 crewcab SE 2wd
  #19 (permalink)
Old 07-04-2008, 11:11 PM
nizmut's Avatar
No the 9" is out of a 84 e150 van with a wheel chair lift
It is 4" wider than a frontier axle and with adapters will be wide enough to go outside the frame with springs and shocks.
But I may have an issue with the rear shackle set up I plan on building. May loose the bed after all and have to come up with something else
  #20 (permalink)
Old 07-04-2008, 11:43 PM
penski61's Avatar
nizmut , pm sent
HTML code is On
