Gear ratio for 37" tires? - Page 2 - Nissan Frontier / Navara Forum
Go Back   Nissan Frontier / Navara Forum > Mods and Technical Discussions > Drivetrain Discussions
Old 02-26-2013, 12:08 PM
BRUTAL's Avatar
I have 4.56's w/33's and i would never consider a 4.10 for 37's, not even 35's. Remember that factory gearing is for what the general public uses the truck for. Alittle towing of thier bass boats and driving on gravel. Go bog or go home. I would do 4.88's if they were avail
Old 02-26-2013, 05:38 PM
JRT.Pro-4x.11's Avatar
Are there any websites online that sell the Titan diff and pathfinder driveshafts together or do you just get the stuff from a junkyard?
2011 Frontier Pro-4x
11.5" of lift with 315/70/r17 MTZs on 17x9 Fuel Hostage
Hypertech max energy programmer, throttle body spacer, INJEN cold air intake, and true dual Flowmaster 50 Series Suv(super 50) exhaust
Old 02-26-2013, 05:44 PM
dan826's Avatar
I got my diff from the junk-yard for $450 in great shape. Found it near me at
Car-Part.com--Used Auto Parts Market
Brand new it is arround $1100 from:
2012 Nissan Titan Crew Cab OEM Parts - The Nismo Shop
The Pathfinder half-shafts are expensive at $410 a piece:
2013 Nissan Pathfinder OEM Parts - The Nismo Shop
You can get aftermarket ones for much less ($78-$164)
2010 NISSAN PATHFINDER 5.6L V8 Drivetrain : CV Half Shaft Assembly Auto Parts
Old 02-26-2013, 07:04 PM
Thanks man I appreciate you helping me. I guess it probably won't be to hard to find a Titan diff at a junkyard because there's probably about 5 in every junkyard with blown motors haha. So why do you have to swap the stock diff for a Titan diff? Why can't you re gear the stock one?
Old 02-26-2013, 08:14 PM
dan826's Avatar
As far as I know, nobody makes gears for the r180. So the current situation is that you can get an m205 and replace gears, or you can keep the r180 and get a locker, but you can't have both.
Old 02-26-2013, 08:44 PM
Oh okay. What would adding a locker do for the gear ratio? I thought lockers were just to make both wheels spin the same right?
Old 02-26-2013, 10:15 PM
dan826's Avatar
Lockers are for off-road use so that if you get one wheel in the air the other still has traction. They don't typically alter the ratio at all. With most lockers you basically replace the entire carrier assembly which is the unit with the spider gears and where the ring gear bolts on and where the axle shafts go in. Typically you take your existing ring gear from your old assembly and put it on the new locker assembly, and keep the same gear ratio as before.
Old 02-26-2013, 10:18 PM
westracing01's Avatar
Feedback Score: 4 reviews
Send a message via AIM to westracing01
EDIT: Dan beat me to it.
JRT: You're an auto yes?
2009 Titan Swapped PRO-4X KC 4x4 6spd...
See my Build Thread for mod list and pics...
"A little government and a little luck are necessary in life, but only a fool trusts either of them."
The words "Titan Swap, cheap, easy, M205, re-gear, quick, coilovers" are not to be spoken in the same sentence.
  #19 (permalink)
Old 02-26-2013, 11:26 PM
Yea it's an auto
  #20 (permalink)
Old 02-27-2013, 09:25 AM
Well, if you wanted to put in a Titan Diff and not re-gear, then you'd need to find one with the 3.36 ratio, which came in the big-tow optioned Titans. However, since you do want to re-gear your options open up some. You need to find a 2007+ diff, any ratio (2.94 or 3.36 but the 2.94's are a little cheaper.)
Figure $400-500 for the diff, $150 or so for a pair of V8 Pathfinder halfshafts from rockauto, front and rear gears from rugged rocks in either 4.10 or 4.56 flavor (get the 4.56's, you won't regret it) along with the install kits (major overhaul kit for the M205 at least, I'd opt for the major overhaul for both) plus a new yoke for the M205 to match the 29 spline pinion, around $900 or so for all of it, plus install of the gears which can range anywhere from $350-600 depending on where you live. So, right around $2250 to regear it unless you can do the gear install yourself. It's not super hard, but tedious and is usually left to the pro's.
Just wanted to give you all the nuts and bolts of what it entails.
The Following User Says Thank You to westracing01 For This Useful Post:
HighALT (03-01-2013)
HTML code is On
