Old 03-08-2008, 09:58 PM
front end noise over bump
I've got one of those curved curbs into my driveway (don't know how else to describe ... ya know, the curbs that are the same throughout an entire neighborhood to save the developer money) ... anyway ...
... when i turn into my driveway i hear a noise like a high-pitch-cranky-crack sound as soon as i hit the curb.
Any ideas on what's making that sound? It only happens when i pull in rather quickly. Doesn't happen anywhere else.
thanks!
2002 Nissan Frontier Crew Cab SC V6 Long
http://www.greatlettering.com ~ design it yourself. it's easy.
http://www.designerwraps.com ~ vehicle wraps.
Old 03-08-2008, 10:36 PM
Tweak'e's Avatar
at full lock?
If so ........ your just rubbing up against the stops. check you haven't worn the plastic ends off the stops as constant abuse like that will severely wear the stops. greasing them regularly helps a lot. its simply easier to not put so much pressure on the steering ie wind back from full lock a fraction. full lock varies depending on who much travel the suspension does (ie amount of full lock changes when hot a bump). so when you hit a bump it pays to let the steering wheel kick back a bit and you will find it makes less noise and doesn't wear the stops so much.
The Following User Says Thank You to Tweak'e For This Useful Post:
sojo (03-09-2008)
Old 03-08-2008, 10:44 PM
mike's Avatar
Originally Posted by Tweak'e View Post
at full lock?
The Following User Says Thank You to mike For This Useful Post:
sojo (03-09-2008)
Old 03-09-2008, 03:03 AM
Tweak'e's Avatar
nicw pic.
it looks kinda like the plastic end is almost worn right on that.
Old 03-09-2008, 11:49 PM
yeah at full lock.
that makes sense ... will "lay off it" a bit when turning over the bump. will also check it out underneath just to be sure.
thanks guys!
HTML code is On
