05 frontier se cc locker
Are there any for an se 4x4 for the rear?
06 Nissan Frontier Crew Cab 4x4 6-speed 00 RANCHER 350 4X4 ES Warn 424 25" Kenda Bearclaws Moose hand gaurds K&N air filter Progressive rear shock 02 PRAIRIE 650 25" Swamp Witches ITP C-series type 7 wheels (Black) Twin Air filter Moose power module 98 SPORTSMAN 500 EBS (Broken) Maier hand gaurds K&N air filter |
If you look at the top tool bar you will find the search button.
yes there is a bunch of threads on this so search.. but you have an M226 Axel, aka fake a$$ dana44, the Titan true track will work with it.
Where we're going, we don't need roads. |
No, no aftermarket locker available yet.
Check out the 2nd Gen FAQ for answers to common questions: http://www.clubfrontier.org/forums/f...005-faq-31965/ 2005 Electric Blue Nismo King Cab 6spd 4x4 Bassani Aft-cat Exhaust, Injen Powerflow Intake, Shrockworks Rock Sliders, Shrockworks Skids, 285/75/16 Nitto Terra Grapplers Misc: Custom Nismo Decals, Access Roll-up Tonneau Cover, ScanGuage II mounted with MGT Motorsports Blendmount, Gentex Auto Dimming Mirror Last edited by EB_05_NISMO : 05-13-2008 at 07:31 PM. |
I drive an Altima...with a CB antenna Quote:
2008 KC 4x4 5A SE - In service 2002 Altima 2.5S - In service <--- what I drive now 2008 Altima 2.5S - Gone 2007 KC 4x4 6M NISMO - Gone 2007 KC 4x4 5A SE - Gone 2005 KC 4x2 6M SE - Gone 2005 Xterra 4x4 SE - Gone 2002 CC 4x2 SE - Gone |
then what the fook is this then? ordered true track if you have a the 6 speed SE you have the m226 axel, same as the nismo, same as the Titans, the titan true track will fit it.. there is video of it in that thread.
truetrac is a mechanical 3:1 limited slip.
Check out the 2nd Gen FAQ for answers to common questions: http://www.clubfrontier.org/forums/f...005-faq-31965/ 2005 Electric Blue Nismo King Cab 6spd 4x4 Bassani Aft-cat Exhaust, Injen Powerflow Intake, Shrockworks Rock Sliders, Shrockworks Skids, 285/75/16 Nitto Terra Grapplers Misc: Custom Nismo Decals, Access Roll-up Tonneau Cover, ScanGuage II mounted with MGT Motorsports Blendmount, Gentex Auto Dimming Mirror |
No It's a mechanical locker, not a selectable locker.
Incorrect. a mechanical (or lunchbox) say detroit style locker actually locks the two axle shafts together so they turn at the same speed under throttle. You also may have heard of these being called ratchet style lockers.
The TrueTrac is a mechanical limited slip that using gearing, requires at least 1 turn of one axle shaft to 3 turns of the other. it does not ratchet, I do not believe it engages due to the throttle. Most importantly, it does not lock both axle shafts in a 1:1 ratio. Hence, its a limited slip.
