I used to run SS lines on my racecar year ago for 2 main reasons. Brakeing force is transfered faster through true SS lines. Secondly being a braided SS line is is far better protected so good value as far as peace of mind .
Rubber lines are not just rubber its just a rubber outer covering.Being a slightly softer covering they will swell under pressure ever so slightly hence transfer the pressure slightly slower.The SS braid will keep the dia of the tube to spec at all times . This means that in theory it will transfer the pressure faster . The only time I would ever expect to see a brake line bubble from pressure is just before it bursts At the end of the day you will more than likely find that the only difference between most of the OEM and SS lines is they are the same line but 1 had a SS covering. However if the lines are high quality top dollar SS brake lines then yes the quality is there and it is worth the effort. How to tell the differance between the 2 differant type of SS lines . Only buy brake lines from a reputable manufacturer.Buy your most important parts from the places Indy and Nascar buy their gear. Quality costs .!!!!!
![]() Black Ice 2007 Nissan Navara ST-X 4x2 V6 6 Speed Dodgey Midnight Black with some Frontier Bits Wheels by Speedy Australia Paint screwed by Nissan Australia " we are on right side of car and opposite side to right is wrong therefore you drive on wrong side lol" Last edited by Aussie Frontier : 06-20-2008 at 09:51 AM. |
Yes, installing SS brake lines should engage brakes faster otherwise no sense to install them.
Nissan Navara D40 LE AT 2006 - RUSSIAN BLACK BOX ![]() |
well i've had these for a while (thanks for reminding me to repost stan
SS Brakes FTW
Thanks for sharing....Now i need to put a set in after hearing bout your expderience
KEEP RIGHT PASS LEFT. What could that mean? Why are you blocking traffic by driving so slow in the left lane? Now get the HELL outta the way!!! Keep traffic flowing...Obey the rules of the road
