Go Back   Nissan Frontier / Navara Forum > Nissan Frontier Forums > Street Trucks
Old 06-06-2008, 04:20 PM
MOBEEBO's Avatar
Hellwig Sway Bar installed!
Well, here we go. The installation was very straight forward without any surprises. The directions are very clear and thorough. I decided not to weld the sleeves in because the bar will not be in rough service.
As far as drilling into the frame is was not very hard. Once the bar is connected loosely to the axle (with the vehicle on the ground) you can connect the end links at a height that result in the bar being horizontal (level, not leaning up or down). Once you mark the spots just drill away!
There is nothing in the way other than the oem exhaust mount on the passenger side that you need to clear. So, on the drivers side, the end link needs to move forward slightly. You can see in the pictures what I mean. It took us about two and a half hours going slow and combined with the Titan diff. cover install. So if you know what you are doing it shouldn't take more that an hour and a half to two hours. It was nice to have a lift handy to raise and lower the truck as necessary though.
Now, as far as driving impressions.... I mounted with the suggested position for street use in the opening all the way back on the bar. Currently it is much more stable yet surprisingly supple. It is not rough or harsh. However I would like to try it in another position to see what kind of increased stiffness I can achieve so I may move it soon. One thing is certain....I NEED BETTER TIRES AND WHEELS NOW! The truck tracks much better at highway speeds, I was doing 80 mph with a heavy cross wind and I could let go of the wheel without the truck wandering around.
Oh, one more thing. The Titan diff. cover clears perfectly, but I had to disconnect the eBrake line from the old covers mount. I will have to come up with a solution, right now it just dangles there. The OEM cover was too hot to touch after a drive home from Napa to Sac (freeway speeds, 62 miles) I can hold my hand on this cover without having to take it off! The larger ones like that Mag-Hitec would be a tight fit with the bar and the spare.
I am sooooo ready for the UpRev now!
Old 06-06-2008, 04:23 PM
Inyourface1650's Avatar
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
ONAZ
Old 06-06-2008, 04:30 PM
MOBEEBO's Avatar
I was just bustin yer bawlz.
Old 06-06-2008, 04:36 PM
All kidding aside, it does hang down alot lower then I was hoping. No way I would go offroading with that on there.
ONAZ
Old 06-06-2008, 04:39 PM
MOBEEBO's Avatar
You can swing it up on the axle. You do not have to have it at a 90 deg. angle. You can go to 45 deg. which would raise it up a few more inches but, yeah. It is a street item for sure, that is why I posted in the Street Truck forum. Also, cause I hate the oversize wheel threads that currently occupy the forum.
Old 06-06-2008, 04:44 PM
mike's Avatar
Actually it looks like the sway bar's lowest point is the same as the rear shock.
Old 06-06-2008, 06:44 PM
Johnnyman88's Avatar
this limits flex right?
Calmini Kit W/ PRG Upgrades
TC UCA's
AC Body lift
WRP GK
JBA Catbak Sys. & AEM CAI
Old 06-06-2008, 07:15 PM
MOBEEBO's Avatar
It limits body roll in turns, which in turn would limit articulation.
Old 06-06-2008, 11:54 PM
NCFronty's Avatar
Looks good for sure. Hellwig makes great stuff.
2006 Frontier CC 4x4 LE NISMO SPORT Stormgray - Performance: Airaid Quickfit intake w/AEM dry filter,WRP I.M.S.,2* Advance,TB Screen removalExterior:Nissan running boards,Nissan hood guard,PIAA Xtreme White Plus bulbs in headlights & Fogs,Black Bullet BullBar,PIAA 520 Ion Crystal fogs, Hidden Hitch,OEM Nismo skidplates,Truck-Tec tonneau,Thule roof rack w/wind deflector,Billet Grill 4 piece set Interior:Kenwood CD player & in-dash 4 Disc Minidisc changer,Panasonic S2 GPS Suspension:PRG 2.5" lift w/Radflo 2.0 Coilovers and 2" Deavers,Rear Bilsteins,SuspensionConnection Titan Sway bar bushings Wheels/Tires:Nissan LE 17" 4 spoke wheels, 265/70/17 Bridgestone Dueler REVOs Other:McMaster-Carr Hood lift mod, Painted windshield wiper cowling
Old 07-21-2008, 04:52 PM
N e one one the size of the stock vs the aftermarket?
How many MM?
I know in my altima i forgot the exact specs of each but it was a 4mm difference and it made A HELL of a difference in roll.
KEEP RIGHT PASS LEFT. What could that mean? Why are you blocking traffic by driving so slow in the left lane? Now get the HELL outta the way!!! Keep traffic flowing...Obey the rules of the road
