biggest rims on 98?
just bought a used 98 frontier its all stock and im wondering the biggest rim size that i can go is? im hopeing its around 18-20"
thnx in advance |
If you SAS, you could probably fit a 28" or 30" rim.
If not, maybe a 18 or 20, it all depends on what tires you go with. |
18s pretty easily. 20s with rubber band tires. you can go bigger, just depends on how much you want to sacrifice.
also note you will want a high offset wheel to avoid fender contact. look for something with +25mm or more. +40 if you plan to bag later on. |
I have the same truck, mines an 01, but I have 18" w/ 235/50s....the correct plus 3, so the speedo is dead on, and rides nice. I love it. See avatar. BTW, those are 2007/8 factory escalade wheels. 20"s would fit wasy, even lowered. I plan on dropping my nose more, and I use mine as a truck...so 18" was perfect for me. (And I have 2 other vehicles on 20"s....tires get expensive)
Greg 86 Buick Grand National 07 Passat Wagon dropped on 20"s 01 frontier X-cab, 3" drop, 18" Escalades |
