| View Poll Results: Which One? | |||
| PRG Setup |
75 | 81.52% |
| 5" Calmini Kit |
17 | 18.48% |
| Voters: 92. You may not vote on this poll | |||
PRG all the way, the spindles setup will give you far more clearance!
![]() 05 CC SE Auto Mods: pathfinder wheels, 4" cst Spindles, 2" rear block, rear bilsteins, 285/75/16 bfg at's, ScanGauge II |
ok boss your back end will be higher than your front with all that added to your rear. The best look and functional avenue i have seen on here is to loose the 2" rear block kit and the deavers and go with his height adjustable shackles. The front will net you at around 6.5 and give you much more room to play than the calmini. If you were to add his Uppers than you are looking at a very durable long lasting set-up. Now if you want it more level do go with his 2" block kit though only put your shackles at 1.5 instead of 2.
That calmini kit is not worth it in my mind because most of the money comes from that front drop-bracket that nets you only an extra inch of clearance. good luck bud. |
You asked so I'll tell. Save the money and don't lift at all. $1400 isn't worth spending on looks since the truck is 2wd IMHO.
But if you decide to lift anyways, stay away from blocks in the rear as they flatten out your springs and drastically reduce ride comfort. Whatever your decision is, lift the rear with Add-a-leaf's or Deaver's/Alcan's, and shackles. I say go with Fabtech over Calmini.
![]() '05 Nismo CC: Banks Monster Exhaust (Sound clips), Pioneer Avic-D1, Raffle Volant CAI, Stryker SR-490, Stryker antenna, Kumho Road Venture A/T's, Shrockworks sliders, Fabtech 6" Lift, Revolver Shackles, AAL's, Snorkel. The fox will never keep the hen-house safe! NObama! Obama a natural born citizen or an Indonesian Muslim? Obama Does Not Have a US Long Form Birth Certificate and Why What were the Crusades all about? -Peter Hammond The word "crusade" is not found in the Bible or commanded and the Crusades ended over 7 centuries ago. Jihad is one of the pillars of Islam and is commanded and still goes on today! |
I read somewhere on here that it's not good to lift higher than 3 or 4" without a drop bracket type lift. IDK, I'm happy with my set up.
06' KC 4X4 SE. Calmini 5" SL, 3" BL, Injen Power-Flow Intake, 295/75R16 Hankook Dynapro RTO3 MT's, Bilstein shocks, Magnaflow exhaust, Billet grill. Hopefully soon to come; PRG UCA & Radflos or SAW's for the front. |
Shackles will flatten springs, blocks promote axle wrap.
| The Following User Says Thank You to EB_05_NISMO For This Useful Post: | ||
06_footy (10-02-2008) | ||
He is 2wd which means that he doesn't need the drop bracket.
NOR IS THE HEIGHT SINCE ITS US 4X4'S THAT HAVE TO WATCH THE FRONT CV JOINT ANGLES
Calmini and Fabtech are absolutely the WORST investment for a 2wd truck! You are putting huge a$$ spacers and drop brackets on your truck and all you get is an inch of ground clearance and declining MPG's. If you want the height/ground clearance go with the CST spindles and a decent set of coilovers for the front; then get the Deaver AAL and adjustale shackles for the rear with a bilstein 5125 or SAW 2.25 remote reservoir shock. I guarantee you will be extremely pleased with improved ride quality and handling; not to mention the sweet a$$ look your truck will have once your done. |
