| View Poll Results: Which term is correct for you regarding the hand brake lever in our Frontiers? | |||
| Emergency brake |
63 | 42.28% |
| Parking brake |
81 | 54.36% |
| Other |
5 | 3.36% |
| Voters: 149. You may not vote on this poll | |||
it be my m-r-g brake. But I use it to park....hmmm. I also think it determines if you drive a manual or automatic.
2007 Crew Cab...Majestic Blue.... RF system, bed extender, Bak flip, Pioneer Avic D3 with Back up camera (all it looks at is the truck bed); AirRaid Quick Fit CAI; nismo cat back |
If you just stopped for some Starbucks, it's a parking brake.
If there's a big open wet spot on a corner where your friends are hanging out, it's an E-brake. if a kid chases a ball into the street right in front of you, it's an emergency brake. If you are on a hot date, it is in the way.
2006 Black CC 6spd SE - Flowmaster 50 SUV - Volant Intake - Throttle Body Spacer - Intake Manifold Spacer - Scanguage 2 - OEM Hood Protector - Nismo Shift Knob - Pathfinder Window Switches. |
that is why I miss a bench seat.
That is only if it is not in use which could be a costly mistake with a manual trans. Let's say you are parked on a gentle slope. You start to get your mack on and realize the brake handle is cramping your game, so you dissengage it to clear access to your partner. In the heat of passion the shift lever is kicked or nudged out of gear and the two of you are rolling along totally unaware until you suddenly crash into something.
Her Dad most likely instilled this into her because setting the parking brakes on older cars would keep the rear drum brakes adjusted. Newer cars with drum brakes have self-adjusters.
![]() '04 "Desert Runner" XE V6 |
that's a bagel restraint device, or brd for short.
Report a bad/flaming/illegal post by clicking on Report Post or |
Does it really matter? parking or emergency....they both work to prevent the truck from moving....
Just call it the hand brake....that way it covers both fields...
Allen 2000 Nissan Frontier Pride is what drives me! Mine has got the works! She's got everything from a set of PIAA Xtreme White Heads and Fogs to a Pioneer audio system to a small-time Calmini suspension lift...not to mention a K&N intake and a throttle body spacer. Dont forget about the dual Flowmaster exhaust with quad tips! Check it out! and Enjoy the View!!!!! Pics of my Victoria: http://www.clubfrontier.org/forums/v...?do=view&g=963 More pics available @ http://www.cardomain.com/ride/2644256 Contact me @ http://www.myspace.com/VentureBrutha Frontiers for life, y'all! ![]() |
Except in first gens, its either foot actuated, or the weird pull pole thing. so its cant be called a hand brake
![]() 1994 Pathfinder Auto 4x4. Mall Crawler. 2007 NISMO KC 6M 4x4 - Gone 2005 SE KC 6M 2x4 - Gone 2002 SE CC 4A 2x4 - Gone ONAZ Last edited by Inyourface1650 : 02-05-2008 at 05:16 PM. |
Parking brake. My theory is that if you drive for a while giving time for the rotors to heat up and then you apply the E-brake then the spot where the pads make contact with the rotors is going to cool down slower. Now, you have warped rotors!
