How long did your brake pads last? - Page 3 - Nissan Frontier Forum
View Poll Results: When did you have to replace your brake pads?
<25,000 miles 9 10.00%
25-50,000 miles 18 20.00%
50-75,000 miles 22 24.44%
75-100,000 miles 20 22.22%
>100,000 miles 16 17.78%
Upgraded before required 5 5.56%
Voters: 90. You may not vote on this poll
 3Likes
post #21 of 36 (permalink) Old 03-25-2013, 05:30 PM
Quoted: 2 Post(s)
2005 SE 4x4.
Replcd. Front pads + Rotors @ 24,398 km. - Warranty
Replcd. Rear pads + Rotors/Replcd. Front pads + service Rotors @ 52,950 km.
Replcd. Front pads + Rotors @ 90,686 km.
Service all pads + Machine Front & Back Rotors @ 121,382 km. (probably a mistake).
ruralroot4 is offline
post #22 of 36 (permalink) Old 05-02-2013, 09:56 AM
60K Was Time to Change
I was impressed with them lastin up to 60K, then I changed them out. Tom
TomInTX is offline
post #23 of 36 (permalink) Old 05-02-2013, 10:19 PM
Derentes's Avatar
as is the case with many parts of the truck, it will depend on how your using it.
I play around in the mud quite often and go for romps thru the woods as frequently as my schedule will allow... so, thanks in part to the ABLS, I only get about 30K out of my pads. But I'm not complaining. It's part of the price of playing =D
Derentes is offline
post #24 of 36 (permalink) Old 10-25-2013, 05:26 PM
CDobrynski's Avatar
running duralast gold pads with stock rotors with about a quater life left after 70k poor things have had a very rough life stopping the 33x12.50 cepeks. upgrading to akibono and new rotors in the spring
2003 nissan frontier .20 over .10 off the heads, ac's s2 cams, hayden electic fan, k&n bird cacher with custom pipe, cat delete (all), flowmaster 40, dt headers, sachs stage 1 clutch, 3' ac lift 2' body lift, henemen fiberglass up front, on board nav system, 32x11.50 dunlop m/t
CDobrynski is offline
post #25 of 36 (permalink) Old 10-26-2013, 06:34 PM
brett3116's Avatar
Quoted: 3 Post(s)
replaced my front rotors and brake pads for the first time at 85k today, but the pads still had a 3rd of the life left on them. They could have gone 100K easily. I checked the rears to see if they needed to be replaced, and they looked like they could go another 85k so I left them alone.
07 Frontier NISMO CC Avalanche, NISMO CAI, PRG 2 inch Leveling Kit, Wet Okole Seat Covers, 2* Timing Advance, WeatherTech Floor Liners and Bug Deflector, Bed Extender, Stainless Steel Nerf Bars, Chrome Window Switch Covers, WRP Grounding Kit
brett3116 is offline
post #26 of 36 (permalink) Old 10-30-2013, 04:44 PM
Banned
JoeR is offline
post #27 of 36 (permalink) Old 10-30-2013, 11:11 PM
Cusser's Avatar
Quoted: 208 Post(s)
Originally Posted by JoeR View Post
A long time ago,, a Smart Feller told me that applying the brake's changed motion Energy into Heat. He said using an Easy Foot on the Brake Pedal was being Energy Conscious and Saves on Gas & Saves on Brakes.
Correct.
Cusser is offline
post #28 of 36 (permalink) Old 10-31-2013, 01:11 AM
HighALT's Avatar
Quoted: 3 Post(s)
Bought the truck with 65k...ish. Just passed 90k. Doubt the brakes were new when I bought the truck. My mechanic said it's about time to get the brakes redone. Not a huge rush but... it's time in the next few thousand miles. Still trying to decide how much to spend on the brake job. OEM or...?
2005 CC SE 6MT 4x4 - Avalanche White
Titan Swap: 2.5 S.A.W. Ext Res C/O's|PRG UCA|PRG Shackles|Deaver AAL|Bilstein Rear Shocks
M205 Front Diff|Titan Shafts|PRG TRE|4.56 Superior Gears|M226 Rear Diff w/ TrueTrac LSD
2" Body Lift|35" BFGoodrich KM2 M/T|17x9 KMC Addicts|AFe CAI|Superchips Tuner|XTP IMS
Hefty Fabworks Full Skid Plate Set|Shrockworks Front/Rear Bumper, Rock Sliders and Rear Diff Cover
HighALT is offline
post #29 of 36 (permalink) Old 10-31-2013, 08:40 AM
Quoted: 11 Post(s)
Killed mines at around 50000km: lost electrical brakes on a heavy trailer (>5000lbs) where there was alot of steep hills, many miles long, in a heavy rainy day... Alot of water on the road, alot of heat on the brakes...
So spotted them and wrapped them. After trying turning them, still alot of spots and vibration, so changed. Still more than 60% remaining on pads, but killed everything
2011 sv 4x4 cc long bed.
4 wheels with tires
a steering wheel
lights and lamps,
glasses where needed,
and lot of satisfaction
chijusa is offline
post #30 of 36 (permalink) Old 09-17-2016, 09:37 PM
Quoted: 10 Post(s)
Just replaced both front hubs today and found out my front pads are just starting to dust the squealers@ 103xxx miles. Looking for new pads now and figured I'd resurrect a long dead thread just to F with the whiners here.
2006 Nismo KC 4x4 6speed
Volant CAI with the powercore filter.
Plastic style intake spacer.
Bullydog GT with mild tune.
New ring and pinion and elocker 30Jan15.
Axle vent.
Cargo light always coming on with door open mod
Swapped rear diff with amsoil
Rear pinion went out towing a heavy load so amsoil is out and now some mobil1 75w140 LS synthetic is in!
Swapped front diff with amsoil
Swapped transfer case with amsoil
Swapped 6 speed manual trans with Redline mt85
^sucked so I swapped in royal purple
^sucked almost as bad so I swapped in Nissan mtf which isn't sucking, amsoil next. Nissan MTF is doing very nicely still!!
Added some LED fogs to blind the idiots with drop in hid kits
Notabiker is offline
  Nissan Frontier Forum > ClubFrontier News and Polls > ClubFrontier Polls
