Go Back   Nissan Frontier / Navara Forum > Nissan Frontier Forums > Off Topic > C/F Photography Club
Old 04-03-2008, 07:00 PM
MateoTheWombat's Avatar
Looks great pearl...tires are beastly, love the view also, your pad is sweet! I took my lady down to sd for our 4 yr anniversary in feb.....we both agreed sd is waaaay better than l.a....friggin beautiful city and not an ounce of ghetoness lol
05 CC SE Auto
Mods: pathfinder wheels, 4" cst Spindles, 2" rear block, rear bilsteins, 285/75/16 bfg at's, ScanGauge II
Old 04-03-2008, 07:02 PM
Lambo's Avatar
I'm trying to "chrome" my truck up, and you're trying to get rid of the chrome....
Old 04-03-2008, 07:06 PM
Thats one bad *** truck man.How much lift you have?
Mods: K&N cold air intake, 40 series flowmaster dual exaust, 3in AC body lift, 5in calmini suspension lift, 33in. BFG mud terrains, custom grill,Pioneer cd player, kicker tweeters, infinity perfect 6x9 and 6.5
Old 04-03-2008, 07:17 PM
TerribleOne's Avatar
Yeah man, when I graduated college and moved back here I ended up in L.A. My wife's cousin had a place he wasn't using there, right off of Doheney and Sunset. He was living in France, but the rent was so cheap he said he couldn't let it go. Anyways Fu(k LA! I was there for 12 days; that was all I could take.
I haven't measured it since I switched the tires; but they are about the same so I don't see it really making a difference. From ground to fender I am at about 42" and stock is 34" if I remember correctly. So I have roughly 8" of full suspension lift.
Last edited by TerribleOne : 04-03-2008 at 07:19 PM. Reason: Automerged Doublepost
Old 04-03-2008, 08:17 PM
BoyInBlue2658's Avatar
did u rattle can your grill black or have it painted? looks good
R.I.P LAPD Ofcr. Randy Simmons "R 41 david" EOW 2/7/08
Old 04-03-2008, 09:13 PM
Shinjari's Avatar
ok, i dont mean to point this out...but in the 3rd pic, is that on level ground?
cuz if it is...i see that the passenger side is higher than the driver side.
06 Storm Grey LE CC 4x2
FORMER Mods: TITAN Swap, Sway-a-Way COs, CST 4" Spindles, PRG Shackles and AAL, Bilstein 5125s, NISMO CAI, Custom Exhaust, 2* advance, Procomp 7089's and 285/70/17 BFG A/T's
Want to learn how to install your PRG spacers and Deavers? Click here
Old 04-03-2008, 09:16 PM
Yup, good ol rustoleum industrial spray paint. I just did 3 coats primer, 3 coats flat black, and 3 clear.
No No No; definitely not level, my back tire is hanging off that cliff a good ways. I have looked at it on level ground and I can't tell the difference. But I will turn the other c/o all the way down and see if both rub again.
Last edited by TerribleOne : 04-03-2008 at 09:18 PM. Reason: Automerged Doublepost
Old 04-03-2008, 11:06 PM
beefy242's Avatar
oh now that looks awesome. so sexy... you should start your own site.
cardomain page:
  #19 (permalink)
Old 04-03-2008, 11:29 PM
so everything was by rustoleum? primer and clear?
  #20 (permalink)
Old 04-04-2008, 12:13 AM
Yes. It was all the rustoleum industrial paint. They have stuff that is specifically intended for industrial use, it' supposed to be much more durable. I also used rustoleum to paint my uppers and lowers. It is holding up really well. It took about 4 hours total; using heat gun to dry the paint in between coats for a stronger finish. Really the key is making sure that you are letting the paint fully dry in between coats.
