Trailblaza Fridge by Norcoast
I purchased a 60L Fridge from Norcoast Pty Ltd of Caloundra with Aluminium inner and outer covers, 75mm insulation, dual temp range, with my own personalized plate (Ozroder Fridge) and I also got an interior light, gas strut, and thick top cover..............S/Steel handles and S/Steel turnbuckle tie downs to keep it in place.
60L gives me enough room to fit drinks on top and meat under for longer stays in the bush............but the idea is to plan the meals in between each town and just carry enough frozen meat to cover those meals..........that way you stock up with fresh food regularly and this does not give the meat in particular time to go off...............
I have not run the freezer long enough on the battery to see how long it takes to drain down to nothing but I expect it would last quite a few days once fridge and items inside have reached full freeze temperature.
Deep Cell battery should not take more than 3 or 4 hours to come back to full charge and when using a battery isolator it will not impact main battery charging at all.
A tip with any camping fridge is to run it on mains power and get it to the operating temp desired before heading off into the bush with all the frozen food items inside and of course to keep the lid open the minimum time when on 12Volt power.........
NORCOAST REFRIGERATION COMPANY PTY LTD - WWW.NORCOAST.COM.AU
Pics to follow in the next day or so but website will show much.........to me it is the Rolls Royce of Camping Fridges.
All the best, Ozroder
Here are the pics as promised..........Ozroder
Australia - The most regulated country in the world!
Australian Banks - The highest fees and charges in the world!
2006 Silver D40 4x4 Navara 2.5L TD, TOTM - Nov 2008, DC Chip, D.I.Y. 2" Body Lift Kit, AR "Trench" 16x8 Chrome Wheels, MT ATZ Tires 285/75/R16, Radflo 3" Lift Kit, TC UTC`s, TJM LR 150L Tank, TJM F.U.G. Armor, Outback Overhead console with Uniden GPS105 UHF/GPS, Scanguage, ARB Bullbar, ARB Rear Diff Lock and Onboard Compressor, Nissan Foggers, IRP Driving Lights, Nissan Snorkel, 2" Ext: Alum. Shift knob. Black Nissan Side Protectors, Black Mustang Stripes, Aluminium Tray, D.I.Y Camper with Roof Top Tent.
Reason: Automerged Doublepost
