Navara front titan diff - Page 2 - Nissan Frontier / Navara Forum
Old 07-18-2011, 02:33 PM
Nissan4Life's Avatar
Originally Posted by dubie2003 View Post
You must atleast re-gear the front with 3.73 to be close enough to your 3.69s but in reality, you should probably regear both to 4.10s if your rear diff will support it.
If you have the 3.69 gears you are kind of screwed. The main reason is they don't make m205 gears yet. and when they do, they do not paln on making the 3.73 gears.
You options right now, are to
1-replace the axle, cheapest. Your diff is still good? Just the axle is bad.
2-get a m205 with the 3.36 gears. Titan swap the suspension and run stock titan axles. Regear the rear to 3.36 to match.
3-Get m205 with 3.36 gears, regear rear to match. Run stock suspension, get pathfinder v8 axles shafts to match.
06 KC NISMO 4x4, 2" prg spacer front, Firestone riderite airbags rear, Schrockwrxs front engine skid, Custom sliders, Hidden hitch reciever, Deck plate Airbox mod/amsoil filter, Momo shift knob removed, back to 06+ nismo knob, 05 pathy flat black wheels, 265/75/r16 Tread Wright Sentinel with Kedge Grip, wireless door lock keypad, cargo light bypass, auto dimming rear view mirror with compass and temp.
http://mrpulldown.blogspot.com/
AlMeRicK (10-17-2011)
Old 10-18-2011, 02:51 AM
Guys,
I keep seeing posts about how they don't make M205 gears yet. What is the deal? The Rugged Rocks website has a variety of gears apparently available. If they don't make them yet, they may never make them because the Titan has been virtually unchanged since 2005. So what's the deal?
Old 09-24-2012, 01:37 PM
AlMeRicK's Avatar
My front differential blown the past week, so is time to make a change.
I was thinking to buy a titan front diff and re gear all to 4.10 ratio (running 33 wheels so it would be perfect)
my navara is the thai version with lsd, so i was wondering if this gears will fit my rear differential.
.- gears for the front titan diff (m205)
https://ruggedrocksoffroad.com/super...04-p-6714.html
.- Gears for the rear differential (m226)
https://ruggedrocksoffroad.com/nissa...tvgk3lea9ui921
I know that the spain navara ( 10 bolt gear) and the thai version (13boltgear), so, this could fit my rear differential? not looking at a locker for this, just want to regear the rear diff.
Old 11-12-2012, 03:01 PM
emu emu is offline
sry but i can´t help you on this one, but i´ve blwn my frontend in 2008 the first time and i´m still looking for a solution.
mine is a 2006 navara (spain)
if r&p fits on your thai version i could work away from that...
so pls let me know
07 Navara LE - 3" BL - 3" SL OME+custom Spacers
315/75R16 - 8x16Dotz Hammada
custom front and rear bumper
http://profile.myspace.com/index.cfm...endid=76402825
The Following User Says Thank You to emu For This Useful Post:
AlMeRicK (11-14-2012)
Old 05-13-2013, 03:20 PM
did anything come of this mite look into this a bit later down the line
