Navara front titan diff - Nissan Frontier / Navara Forum
Old 07-14-2011, 05:39 PM
AlMeRicK's Avatar
Hello everybody, i was wondering if any differential of the titan would fit to my nissan navara, is the same one form australia. i broke my half shaft and want to upgrade my front diff. then i would buy the titan mid travel.
Old 07-14-2011, 06:07 PM
Mandangalo's Avatar
Don't know the answer, but if u find out it works I have a diff for sale
Old 07-14-2011, 07:00 PM
rorybellows's Avatar
it should, shouldnt it? navarra is the exact same thing as the frontier, yes no? except we no get the deezel
'07 white 6 speed se crewcab, longbed, calmini db lift, blacked out steelies, 33's, herced front/rear bumper, dynomax ultraflow muffler sans resonator, aFe dry filter c.a.i., more to follow
Old 07-14-2011, 07:05 PM
AlMeRicK's Avatar
i guess is the same thing, but the gears may change, or something
if it fits, i would buy you the diff!
Old 07-14-2011, 07:08 PM
dubie2003's Avatar
Your OEM Titan gear ratios are 2.94 or 3.36. Once you know what you have you can go from there.
I'd suggest that you go with a gear swap and etc... but unsure about your rear diff since there was some Navara m226s that had a special ring gear bolt pattern.
07 SE CC Auto
Old 07-14-2011, 07:30 PM
AlMeRicK's Avatar
Nissan Navara l Nissan Chile
here i found somthing, it seems that the nissan navara gears are 3.692
http://www.nissan.com.au/webpages/re...pecs_May11.pdf
and here a australian website, my model is dualcab rx PU 4x4 diesel. and the final drive ratio is 3.692...
so there it is...
Old 07-14-2011, 08:32 PM
dubie2003's Avatar
The only way to run an m205 in the front of your rig is to re-gear once gears are available for the m205. You will probably be able to run 3.73, 4.10 or 4.56s.
07 SE CC Auto
Old 07-14-2011, 08:35 PM
AlMeRicK's Avatar
i must re gear in the front with the titan diff , and rear also?
Old 07-14-2011, 08:41 PM
dubie2003's Avatar
You must atleast re-gear the front with 3.73 to be close enough to your 3.69s but in reality, you should probably regear both to 4.10s if your rear diff will support it.
07 SE CC Auto
Old 07-14-2011, 09:01 PM
ive been contemplating a toyoter front diff. stronger than the 180 and probably just as strong as the 205, plus gears. anybody tried this already?
The Following User Says Thank You to rorybellows For This Useful Post:
AlMeRicK (09-23-2012)
