FABTECH 6" Lift Kit
Hello all, is anyone running the Fabtech 6" Lift Kit?
I will get this is in the near future as part of my next generation upgrades but I have some questions for now: Do you use standard size/length shocks on the front? Is this kit a straight bolt on? What are the largest diameter 16" tires that can be fit with this kit? Is the 6" lift only with the kit or is it say 4.5"/5" lift plus larger tire size? Been dragging my b elly too much in the Victorian Alps, got some decent dints in my TJM 150L. Fuel tank and want to lift this baby up quite a bit. All the best, Ozroder
Take your rubbish with you. 2006 Silver D40 4x4 Navara 2.5L TD, NOVEMBER TRUCK OF THE MONTH 2008, DC Chip, D.I.Y. 2" Body Lift Kit, American Racing "Trench" 16x8 Chrome Wheels, Mickey Thompson ATZ Tires 285/75/R16, Radflo 3" Lift Kit by PRG, Total Chaos UTC`s, TJM LR 150L Tank, TJM F.U.G. Armor, Outback Overhead console with Uniden GPS105 UHF/GPS, Scanguage, ARB Bullbar, Warn XP9.5 Winch (When it works!), Nissan Foggers, IRP Driving Lights, Nissan Snorkel, VMS - A.V.N.C.2265 GPS-Street/Offroad Maps Nav./DVD/MP3/CD/Bluetooth/Head Unit/2" Ext: Alum. Shift knob. Black Nissan Side Protectors, Black Mustang Stripes. |
I am running this kit and so far I'm happy with it. It's basically a bolt on kit, but there is some cutting required and best to have this done in a shop. You will need an alignment when you done for sure.
Yes, I still have stock shocks in place. Ultimatley I will replace with radflo but will stick with stock length. I am running 295/75/16 - so basically 33.4" Probably could go bigger they say 35" with some trimming, but without gears this was big enough for me. Is the 6" lift only with the kit or is it say 4.5"/5" lift plus larger tire size? No, my front bumber was 6" higher after lift was installed (with stock tires) now with bigger tires I'm up about 8" Been dragging my b elly too much in the Victorian Alps, got some decent dints in my TJM 150L. Fuel tank and want to lift this baby up quite a bit. Yea, I hear ya. Hope you got some protection under there.
I will run with a 2" body lift also if I can get one as I want to run tires that are 34.5/35" without issue..................my current setup get my right wheel rubbing on right hand corners and its a pain...............but I will check this out after I do the lift. All the best, Ozroder
All the best, Ozroder[/quote]
| The Following User Says Thank You to bigdog For This Useful Post: | ||
Ozroder (08-05-2008) | ||
Hello Bigdog, thanks for that link to the Fabtech pages, yes there is an amount of fabrication required that I do not wish to perform too.
I think from what I have seen that the Fabtech kit is the better of all out there but I am not happy that it is not a direct bolt in arrangement, this will cloud my wishes quite a bit so again thankyou for the insite into fitting a Fabtech setup. All the Best, Ozroder
sorry but i had to ask how does 33.4 tires give you 2 inches?? 1 inch bigger than stock, you have to cut it in half, so every inch is about .5 inch of lift or alittle less.
Calmini Kit W/ PRG Upgrades TC UCA's AC Body lift pro comp setup 305/70 MT 8089 alloys WRP GK JBA Catbak Sys. & AEM CAI |
before ![]() after ![]() The results were a 6" increase at this point in the bumber. then after tires I measured again and it was 8.5" Maybe this is because a 295/75/16 is 33.4" when sitting on a 10" wheel (295mm = 11.6") and when on a 7" wheel they stand taller. I don't know the answer, its not what i expected. Stock for me wass 30" and I went to 33" that should have been an additional 1.5" but it turned out to be 2.5" maybe now that they are mounted on 8" wheels I should measure again. I set up the same shot tommorow and post it here. Be interested to see the results.
2006 SE CC 4x4 A/T: NISMO CAI, JBA Catback, Unichip PNP, Fabtech 6" Lift w/PRG UCA and Radflo 2.0, ProComp 7089 w/Nitto Terra Grapplers (295/75R16), UnderCover Tonneau, Skid Plates, Warn M8000 Winch w/Multi-Mount, CW Billet Grilles... ![]() "I'll keep my guns, freedom, and money. You can keep the change." Vote Sarah Palin for President in 2012! Last edited by bigdog : 09-04-2008 at 01:09 AM. |
