D40 turbo diesel engine issues. - Page 2 - Nissan Frontier Forum
post #11 of 52 (permalink) Old 08-16-2009, 06:17 AM
Hiromar's Avatar
gd on ya martin
I appreciate mate, thanks...
STX 07 TD 6 Speed 4x4 DC, 17 inch 6 spoke Nissans with Cooper ATR, WARN winch with Nissan bar, Drive lights, Snorkel, Rear bars with hard cover, Ladder racks, 35% Tint, Door mouldings, Alloy scuff plates, YAESU 857-D UHF/VHF, Chrome Grille. Plenty more coming.
Hiromar is offline
post #12 of 52 (permalink) Old 08-17-2009, 07:22 AM Thread Starter
well i got mine sorted...without spending anymore money...
turns out all that was needed was for the ECU to have the LEARNT part of the ECU reset - so everything it has learned, was cleared. I was told it has somthing to with the learning algorithms and the way the injector pump times/ meters the fuel etc. So the fuel rail pressure was getting too high at idle because the ecu was telling the pump to deliver too much etc. Still have no idea why it went bad in the first place and niether did nissan, but it has been fine more than 2-3 weeks now...???? oh well... anyone else with these type of problems should have this done as it costs nothing and only takes 2mins... if it still occurs then you have further issues...
groper is offline
The Following User Says Thank You to groper For This Useful Post:
gordonj (08-04-2012)
post #13 of 52 (permalink) Old 08-17-2009, 09:51 AM
Who reset the ECU for you?
Didnt the dealer do this for you when you 1st told them about it ?
Just remember after every fuel filter change you must clear the ECU.
Cheers Martin
06 STX TD 6sp with just a few extras
Love my old Bevel Ducati's
Martin from Downunder is offline
post #14 of 52 (permalink) Old 08-18-2009, 08:45 AM Thread Starter
Yes the dealer did it. They initially did not know to do this... It was only after they figured it out on another navara under warranty, that they called me in to do mine ( as i had to pay out my own pocket)
None of the diesel specialists suggested this as a fix when i described the problems i had...
It was not simply clearing the error codes, it was resetting the injector pump learning that fixed the problem.
groper is offline
post #15 of 52 (permalink) Old 08-18-2009, 06:00 PM
Tweak'e's Avatar
what ever you do don't go back to those idiots......clearing injector learning is part of NORMAL SERVICING ! ! ! ! ! !
its done everytime the fuel filter is changed so it can relearn the new fuel pressure rate with the new filter. its one thing that seams to catch out the DIY'ers.
Tweak'e is offline
post #16 of 52 (permalink) Old 08-18-2009, 08:42 PM
Sure would love to know the post code where the deal is situated so none of us go there
Cheers Martin
post #17 of 52 (permalink) Old 08-24-2009, 03:27 AM
Hiromar's Avatar
So we have to learn to be mechanics on our cars, so we can teach the experts how to maintain our cars.. for fk sake.
that is disgraceful.
then they call us anal cos we stay on top of them...
Hiromar is offline
post #18 of 52 (permalink) Old 09-20-2009, 06:14 AM
mad st-x's Avatar
That happened to me once too. Put my foot down to beat traffic, took off like a dog shot in the arse, then nothing, thought i'd broken a throttle cable till i remembered it's fly by wire. Limped about a k or so and decided to switch it off for a few seconds and bingo, right as rain. That was about a week ago, hasn't happened since but i'm glad i read this thread. Has anyone who thought they fixed this issue had any more troubles?
mad st-x is offline
post #19 of 52 (permalink) Old 11-30-2009, 10:27 PM
Originally Posted by Martin from Downunder View Post
I've had mine go into limp mode several times BUT only when I was running a tuning chip and I had turned it up to high , Like Tweek'e said over fueling sounds like the problem, once I was able to install a new fuel filter and the engine ran without me having re-set the fuel curve 2000km later it started to play up , pulled over and re-set the curve on the side of the road 5mins later all was well again and never missed a beat since then
Try this before you buy any parts
To clear the codes from your ECM do as follows
How to Set Diagnostic Test Mode II (Self-diagnostic Results)
1. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
2. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the MI starts
blinking.
4. Fully release the accelerator pedal.
ECM has entered to Diagnostic Test Mode II (Self-diagnostic results).
How to Erase Diagnostic Test Mode II (Self-diagnostic Results)
1. Set ECM in Diagnostic Test Mode II (Self-diagnostic results).
Mode II (Self-diagnostic Results)" .
2. Fully depress the accelerator pedal and keep it for more than 10 seconds.
The emission-related diagnostic information has been erased from the backup memory in the ECM.
3. Fully release the accelerator pedal, and confirm the DTC 0000 is displayed.
or in short
Ign on count to 3
full on and off throttle 5 times within 5 sec's
count to 7 hold throttle down for 10 or so seconds
wait for the ECM light to flash let go of throttle and your in count the codes after you have written them down or fell you don’t need any codes just hold the throttle down until you see the ECM pattern change to ten fast flashes twice and then ten slow flashes and there you have one reset ECM
ok so i tried this just now because i am having problems with my nav i believe it occurs at the peak of my boost (3000 rpm) exact and then the van goes into limp mode.. the van sounds and acts normal from 3000rpm and below but once it attempts to pass thats it. i dont even hear the turbo.. so i am assuming that it is what someone stated before (the boost pressure controller failing) because at some times i see black smoke behind the van while i attempt to cross 3000rpm ( this takes a while ) in limp mode...
but now im puzzled because if it was the turbo boost controller wouldnt the van be spittin out smoke before limp mode whilst on boost? and i believe i put bad diesel in my van..
anyways i tried reseting and when it reaches the point where i have to see two fast flashes of ten and one slow of ten .. i see 3 fast 10s and 1 slow ten.. error code?? can someone help me? thanks
does anyone know how to drain the fuel pump / filter for dregs
new development .. i just realised that the fuel pump thing to press is soft and anytime i press and it gets hard after a while it gets back soft.. help?
Jon_One is offline
post #20 of 52 (permalink) Old 12-04-2009, 04:51 PM
ok well i fixed it... it was the air filter
Jon_One is offline
  Nissan Frontier Forum > Nissan Frontier Forums > Navara - International
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
