what is redline for the 2.4L?
for some reason trucks with manual transmissions dont come with tachs so i put one in.............. but what is the readline?
CURRENT: tokico shocks,Energy suspension sway bar kit, pacesetter header with 2.500 flowmaster exhaust and shortened shifter FUTURE: suspension lift an air locker and some pro comp mud terrains on some black crawlers |
mine came with a tach from the factory and it redlines right at 5800 rpms but ive never hit the rev limiter so i dont know about how high it will go or if it even has a rev limiter
you dont want to hit red line while racing. max torque is at 4400rpms, so sometime either right before or at is when shifting would be optimal.
yeah and mine came with a tach too, but i dont really need it....
![]() cardomain page:http://www.cardomain.com/ride/2425259/1 itsmynissan page: http://itsmynissan.com/beefy242 gamertag: The Real Johnso Myspace:http://www.myspace.com/cutestshitever I have a truck. It gets me from A to B. Why I spend so much money changing it, I will never know. Is there a cure for this disease? I have no idea what I would be using all my money for if there was a cure. ![]() |
yea I think its 5800, the way i found mine was just put it in neutral and gas it and rev it up until it hits the rev limiter. once the rpm wont go any higher then you found it. Not going to hurt it that's why the limiter is there.
Its only an offroad truck if you take it off the road. 10" Alpine sub/Alpine 400 rms amp, ScanGauge 2, Fog Lights, Clutch bypass switch, Hardwired 400w inverter, Back-up lights, Reverse Lights on/off/norm switch, Shackle Lift with helper Springs. 99 Frontier KC XE 5spd 2wd manual everything ![]() |
thanks guys!
how did u instaill your tach in ur 2.4, what wire is it
