Old 11-18-2007, 08:22 AM
Zero Six LE's Avatar
Originally Posted by JP99XE
my fronty is 4 banger, doesn't this engine have a timing chain? if chain then it doesn't need to be replaced, right? I'll check out the hoses, belts, idlers, t'stat. spark plug wires can be done anytime, right?
I saw white dry on bottom of guard under engine and I had to add a quart of coolant. I guessed that water pump is leaking so I drove around a bit to find leak when engine was hot. Coolant level must've got low, because needle started moving up above normal temp. Stopped at garage immediately and saw a bit of steamy smoke coming from fan pulley where pump is. can't tell if it's leaking through weep hole or somewhere else, but no coolant coming from anywhere else.
You should not need a timing chain replacement. Like I said earlier, I had 165,000 miles on my 4 banger with the original water pump. The chains are really durable unless they changed something in the later 2.4 liter engines. The water pump is really easy to replace on the 4 banger. How well is your cooling system maintained?
02 Maxima SE Tungsten Blue
Old 11-18-2007, 01:40 PM
NissanTy's Avatar
for our v6's i think at every timing belt replacement they put on a new water pump and seals and do a coolant drain and fill, and if your drive belts need replaced they'll do them also.
Tyler
Old 11-18-2007, 10:12 PM
Pretty sure the cooling system was poorly maintained. Most people just drive and do nothing. I bought the truck used, noticed the engine compartment was a bit grimy so I made an offer that I was comfortable with and drove away with a smile on my face. Gonna get need winshield wiper arms because they worked loose and chewed up the aluminum.
today's job took just about three hours with a nice pace, started with degrease using orange citrus spray, drained radiator, took out shroud, fan and radiator. got rid of bug and brush debris. went to autozone and bought three new belts, scraped old silicone off. put on Blue gasket goop new gasket, new studs for fan. tensioned new belts, radiator and shroud back in, filled it up with antifreeze and turned it back on. No more leak.
Thanks everyone for the belt, pulley advice, it was the right time to do the belts.
JP
Old 11-18-2007, 10:15 PM
JP
Roger that. Glad you got er dun.
Old 11-19-2007, 11:11 AM
fusionfronty99's Avatar
still not a bad idea to check the chain
-Josh-
99 Nissan Frontier XE V6 4X4
AC, Calmini, Ballistic Fab, Bilstien, KC, Shrockworks, BFG, L&P, SLR, Copperhead Fab, Pro Comp, Cherrybomb, K&N
Yeah, it's the new king of everything,
and b*tches don't say no to me, I'm like a wedding ring.
Old 11-19-2007, 11:40 AM
The water pump bolts up to the front of the timing chain cover. You would need to tear into the gear housing to check the timing chains.
Old 11-19-2007, 11:53 AM
if he has it off then y not just take off the timing chain cover to make sure all is well?
may find sumthin wrong
-Josh-
Old 11-19-2007, 02:02 PM
Mainly because he's already done.
  #19 (permalink)
Old 11-20-2007, 01:10 PM
FrontyCrew61's Avatar
How difficult is the timing belt , water pump job. IM handy on my truck, but never did that before.. hours, tuffness.?
Custom Sound (subs amps headunit and fuses), Tint, Gibson Sweptside2.5 Exhaust, KnN filter Cold Air Intake.
