Old 11-17-2007, 02:46 PM
water pump replacement soon, how long and what else to do at same time?
Gonna buy a waterpump today from CHecker auto,
I don't have a chilton's or shop manual.
How long should this job take and what else should I do while i have the covers off.
thanks,
JP
Old 11-17-2007, 02:52 PM
NissanTy's Avatar
timing belt if you need to replace the water pump.
Tyler
Old 11-17-2007, 03:12 PM
Zero Six LE's Avatar
Do you have a V6 or 4 banger?
02 Maxima SE Tungsten Blue
Old 11-17-2007, 04:03 PM
I'd do a full coolant flush since you are going to be messing with the coolant. Also get a thermostat (I recommend Nissan OEM only). Pick up some Fan belts if the one on thruck look bad.
Old 11-17-2007, 04:07 PM
Send a message via AIM to ZmagDnim
Do all your belts, t-stat, coolant of course, plugs, wires. I'll get you a link later where you can buy everything together, I don't have time to look for it now.
-Zach
'02 Frontier with abunch of stuff
Old 11-17-2007, 04:09 PM
What happened to your water pump? I had 165,000 miles on my 95 KC XE and it still had the original water pump on it when I sold it last year.
Here are some kits at CourtesyNissanparts.com for the timing chains and belts. Water pumps come with them.
http://www.courtesyparts.com/Merchan...ode=D22-TBKITA
http://www.courtesyparts.com/Merchan...e=D22-TBKITV6A
Last edited by Zero Six LE : 11-17-2007 at 04:12 PM. Reason: Automerged Doublepost
Old 11-17-2007, 04:36 PM
fronty2wd's Avatar
If your in there to do the water pump and you are even close to time to need the t-belt replaced do it all. Pump, thermostat, t-belt , tensioner, cam seals, crank seal, belts, and check all of your idler pulleys to make sure they are still turning smooth. Also check all of your radiator hoses and there is one hose on the top of the thermostat housing that you should replace while you have the covers off otherwise when it decides to leak(and it will i promise) it's a real pita to replace.
Old 11-17-2007, 06:19 PM
fusionfronty99's Avatar
hey zero 6 LE,
you in the seabees?
my dads in it, NMCB 21 (i think thats it)
anywhoo, back on topic, sry
-Josh-
99 Nissan Frontier XE V6 4X4
AC, Calmini, Ballistic Fab, Bilstien, KC, Shrockworks, BFG, L&P, SLR, Copperhead Fab, Pro Comp, Cherrybomb, K&N
Yeah, it's the new king of everything,
and b*tches don't say no to me, I'm like a wedding ring.
Old 11-17-2007, 06:42 PM
Same ones I was gonna link.
-Zach
Old 11-18-2007, 12:33 AM
my fronty is 4 banger, doesn't this engine have a timing chain? if chain then it doesn't need to be replaced, right? I'll check out the hoses, belts, idlers, t'stat. spark plug wires can be done anytime, right?
I saw white dry on bottom of guard under engine and I had to add a quart of coolant. I guessed that water pump is leaking so I drove around a bit to find leak when engine was hot. Coolant level must've got low, because needle started moving up above normal temp. Stopped at garage immediately and saw a bit of steamy smoke coming from fan pulley where pump is. can't tell if it's leaking through weep hole or somewhere else, but no coolant coming from anywhere else.
