Old 06-25-2008, 04:46 AM
Water pump leak?
I have a 2000 Frontier 4cyl with only 50k. When I was changing the belts I noticed what appeared to be coolant residue on the bottom of the front of the engine. It looks to have been there for some time as it was white in color. I havent actually seen a drip and my overflow/radiator appears to stay full.
I dont really want to replace the water pump if its not really necessary at this time. Is there a "weep hole" that the coolant could be leaking out of? What do you guys think?
Thanks.
Old 06-25-2008, 10:02 AM
fronty2wd's Avatar
On the bottom of the waterpump there is a weep hole. You have to look from underneath to see it or use a mirror from the top. If your water pump is leaking you will know by looking at it.
