Old 02-18-2007, 10:35 PM
Unhappy Truck won't start
My wife has a 2002 Frontier S/C that died on the way home the other day. She managed it to restart it and get it home. The next day I started it no problem but after a few minutes the idle got slower and slower and finally died. I have not been able to start it since.
Now I know these tyoes of problem are almost impossible to solve over the internet but I do have a question. When I turn the key forward (not engaging the starter) there is a clicking noise coming from under the vehicle, right by the tranny. Is this normal? Can someone tell me what this noise is? It sounds like a relay that is clicking really fast.
EDIT: Truck is turning over. Starter/Battery/Alternator all fine.
BTW, the truck has no CEL and I have replaced the fuel filter and checked the air filter. Tomorrow I am going to check for spark to help rule out a ignition problem.
Thanks!
Old 02-18-2007, 10:50 PM
Frontier2's Avatar
Sounds like your batt. is dead,if it won't spin over it just clicks.Your alt. might be going south,and or batt.Good Luck.
06 MAJESTIC BLUE 4X2 LE KC
Old 02-18-2007, 10:54 PM
Sorry, I should have been clearer. The truck turns over fine, it just won't start.
Thanks though!
Old 02-18-2007, 11:28 PM
could possably be the fuel pump, i know when i had my camaro, i switched it over to a FI from carb, and had the electric pump go out, it would do the same thing, keep on turning over but not starting (no fuel getting to it)
see pics of the truck Here
2004 XE 2.4l I-4
part of The Lifted XE Club!
F.W.O West Coast Chapter
MODS: Total Chaos Long Travel Kit, Shock Hoops, Fox 2.5 coil overs w/ eitbach springs, Fiberglass Fenders, Dever progessive add a leafs, Panasonic CQ-C7303U Clarion 4 channel 400W amp pushing a set of JL audio 6.5 Compents, MA Audio 400w 2 channel amp pushing Kicker Comp 10", XM Radio, Magnaflow 2 1/4 in/out dumped before the axle. 5% tint on rear windows 35% on front windows, oval fog lights from kragen.
Soon to be mods:engine brace,
Future mods: Rear Deavers
Old 02-18-2007, 11:54 PM
I was thinking it might be the fuel pump, I'll pull a fuel line and crank the engine over and see what happens. I should have done that while I was changing the fuel filter.
Thanks.
Old 02-19-2007, 12:00 AM
just remeber theres three things needed for combustion. Fuel, Air, and Spark.
2004 XE 2.4l I-4
Old 02-19-2007, 09:45 AM
In the correct amounts.
Hopefully I can get this figured out. I'll post back here with the results.
Thanks!
Old 02-19-2007, 02:36 PM
yeah, sounds like an FSU problem....fuel sending unit. nissan has a full recall going on those right now....go to a dealership and have yours checked out...if its that, they will check i t nd replace it for free. if its not,just tell them you don't want anywork done, unless you are still under warranty
2002 Frontier SC Crew Cab Long Bed Canteen Green
2" Sups and 2" BL
Rancho RS5000 Shocks
Shrock Front Bumper
4 Hella FF100's 2 IPF Driving Lights
265/75-16 MudKing MT's
Delta 50 FlowMaster Exhaust
TJM Snorkel
Warn Manual Hubs
Old 02-19-2007, 06:27 PM
I just looked up the recall. Looks like rust on the connectors has been causing failures. Is there any way I can clean these myself so I don't have to pay for a tow?
By any chance does some one have a diagram of where these connectors are located?
Thanks!
Old 02-19-2007, 06:51 PM
Aussie Frontier's Avatar
sounds to me like your fuel pump has given up. Even tho they can pump huge amounts of fuel it only takes a small spec of dirt to stall the pump.
I would put money on it that if you replaced the pump then it would be good as new again
Black Ice
Dodgey Midnight Black with some Frontier Bits
Wheels by Speedy Australia
Paint screwed by Nissan Australia
