Old 05-13-2008, 09:37 PM
slow95tsi's Avatar
tire size clearance question
Are any of you running 15" wheels ?
If so how big of a tire can you go with a stock ride hight?
I was thinking about going from my 16's to 15's so I could get a better selection of tires. I think in most cases the 15's cost less too. My plan is to make the truck a little more off road friendly maybe with a 33x10.5x15.
The ideal set up I would like to do is a tire 33-35 tall ( If they clear ) but only 9" wide so they dig in better and have less rolling resistance to them.
Patrick
Old 05-13-2008, 10:25 PM
31x10.50's are no big deal, worst case scenario crank the tbars a little bit and add a set of shackles for a $50 lift, but you're gonna have to do some serious work to stuff 33's in there
Old 05-14-2008, 02:50 AM
my truck came stock with 15's
there is no way you will fit anything bigger than a 31 or 32 10.5 with the stock height
I'm running 31x11.5 and I got a tiny bit of rub before trimming
to run the bigger tires you want you WILL need to get a lift
soon to come
SAS baby
SAS count down-
36" swampers
front R&P
rear R&P
rear locker
t-case crawler gears
Old 05-14-2008, 08:47 AM
TxFront's Avatar
With the stock 15 inch rim with no lift the biggest tire you can fit is 31x10.50
2003 CREW CAB
Future Mods
