Timing belt 3.3 V6 - Page 8 - Nissan Frontier Forum
 1Likes
post #71 of 201 (permalink) Old 09-18-2010, 02:58 PM
Timing Belt
Well, I got it all apart and there is an 8" section of the timing belt with no teeth on it so that is the culprit! Just a question for all you knowledgeable folks now. To put the new timing belt on, here is what I believe the alignment should be, please tell me if I'm wrong. Before I took the crank pulley off I made sure it was lined up with the first notch on the left, which in the book should be TDC. On my two cam pulleys, there are punch marks and then there are punch marks on the rear of the timing belt case, so I believe I need to line up those punch marks. Then I should be all set to put the new belt on right? As a check, the distributor should be pointing to cylinder 1's contact right? I believe this is all I need to do to correctly put the belt on. If there is something I am missing, any advice would be appreciated so I don't destroy the thing! Thanks all.
'02 Frontier XE 3.3L V6
Chesuncook is offline
post #72 of 201 (permalink) Old 09-18-2010, 04:30 PM
AngryMallard's Avatar
Quoted: 2 Post(s)
Send a message via AIM to AngryMallard
The crank and cams should be heavy enough to where they won't move around after you remove the belt. They all have marks for TDC though, and if you get a Nissan belt for it, the belt has marks that line up with all the marks that are in there already.
When you get on the engine with the breaker bar to turn it over a few times, make sure you put the new belt on first and don't spin the crank without the cams turning too. That's normally common sense but I figure I'd just remind you...
You don't need to remove the spark plugs either. When you crank it over by hand you'll fight compression on the engine but it's no big deal.
'99 XE-V6 KC 4x4
Also:
'72 VW Super Beetle
'06 Honda Shadow
'71 Yamaha 175
AngryMallard is offline
post #73 of 201 (permalink) Old 09-18-2010, 04:36 PM
Quoted: 2 Post(s)
Also your marks sound like they're lined up properly. I'm not sure about the distributor though. It seems like if cylinder 1 is at TDC, that's when you'd want that cylinder to fire, so the distributor should be lined up to fire that cylinder. You could pull that one plug out to check if you can look down in there and see the top of the piston.
I think I had put on here how many teeth of the timing belt are in between each marking as an extra sanity check. If the old belt is factory though and not in shreds you can transfer the old markings off of that belt onto the new one just to be extra sure.
'99 XE-V6 KC 4x4
Also:
'72 VW Super Beetle
'06 Honda Shadow
'71 Yamaha 175
post #74 of 201 (permalink) Old 09-26-2010, 04:26 AM
Hunterman's Avatar
Quoted: 4 Post(s)
Still in the process of installing the timing belt in mine.
It was replaced by a auto shop at 110,000.
Since the water pump wasn't replaced I had to take it off in order to install the new water pump.
I noticed when I took the cover off, the Factory Nissan timing belt was installed backwards. The letters and arrow were facing the engine, not the front of the truck :/
Surprisingly, the truck had ran just fine.
I have everything lined up, the belt facing the right way and I am having my mechanic neighbor stop by to check my work in the morning just to make sure I am not messing up anywhere. I can't afford a new engine lol.
2001 Nissan Frontier v6 Desert Runner // 31" BFG ALL-TERRAIN tire, Dynomax exhaust, Airbox Mod, K&N drop-in
2007 Jeep Wrangler Rubicon // 35" Nitto Mud Grappler tire, stock-*** exhaust, rugged ridge snorkel, K&N drop-in, 3.5' lift
Hunterman is offline
post #75 of 201 (permalink) Old 09-26-2010, 01:21 PM
adorsey's Avatar
Quoted: 3 Post(s)
Well I just replaced mine. I noticed while taking everything apart that the belt was in pretty decent shape but there was A LOT of play with it. I did everything Nissan recommends even though the seals were in perfectly good shape. I also had to replace my radiator and I went ahead and replaced the fuel filter. I don't think the truck as ever had a fuel filter since the stuff I poured out was black as black gets. I also did the distributor cap and rotor just for good measure. I'm right at 109,000 and mine had a lot of slack so make your own judgment on waiting with this.
Good luck guys.
adorsey is offline
post #76 of 201 (permalink) Old 09-26-2010, 02:11 PM
Quoted: 2 Post(s)
It's like, how much more black could this be? And the answer is none. None more black.
'99 XE-V6 KC 4x4
Also:
'72 VW Super Beetle
'06 Honda Shadow
'71 Yamaha 175
post #77 of 201 (permalink) Old 09-26-2010, 05:51 PM
adorsey's Avatar
Quoted: 3 Post(s)
Yeah it was pretty bad. I don't even want to think of what that has done to my engine.
adorsey is offline
post #78 of 201 (permalink) Old 09-28-2010, 09:48 PM
I just finished doing this. It was not as bad as I thought it would be. This forum was a huge help. Thanks guys.
2001 Frontier 4 Door 3.3
1960 VW Beetle Std
1956 VW Beetle Euro Ragtop, 2276cc
Downsbs is offline
post #79 of 201 (permalink) Old 10-12-2010, 05:20 PM
ahs46's Avatar
Quoted: 4 Post(s)
Timing Belt Attempt #2
Thats right, I'll be changing my timing belt for the second time but not because of miles haha. I changed it at around 140 i think and yeah it was definitely shot. S i put on the new belt and tensioner but i tightened up the belt too much and its been whining for the past 8000 miles. I was hoping it would go away but it never did and i can't stand the noise anymore ha. SO now wiht about 148K im goint o do this again. Might be able to take pics this time. Also, using an impact wrench on the crank bolt is the way to go (never got it off with a breaker bar). Also, MAKE SURE YOU USE THE FEELER GAUGE WHEN SETTING THE TENSIONER so you don't end up like me ha. BTW very helpful sticky and posts guys!
Alec
02 Desert Runner 255k Miles
5-Speed
BFG Rugged Terrain T/A's
Pioneer Head Unit
Kicker Door Speakers
ahs46 is offline
post #80 of 201 (permalink) Old 10-24-2010, 02:11 AM
ahs46,
I was just looking in my Chilton's repair manual concerning these timing belt replacements and it has a bolded note that says:
Also check the tooth design on the camshaft or crankshaft sprockets. Some models may have teeth with a SQUARE edge at the bottom of the sprocket groove, while other models are ROUNDED. The replacement belts are available as either straight-toothed or rounded, and they are NOT interchangeable. Use only a belt that matches the tooth design of your sprockets. Use of the wrong belt will cause whining noise and premature failure.
ahs46, thought maybe your truck's belt was incorrect.
I'm tackling this job right now. It's been a challenge, as I had misplaced my puller and had to fabricate one, then struggled getting the bolts out of the camshaft sprockets so I could replace the seals behind it, then finally had issue getting the seal out of the crankshaft. Hopefully getting it all together tomorrow. My truck had 118,000 miles on it, but the timing belt looked good, no damage but did have a little slack. I decided to do the job when my truck started leaking coolant, most likely the waterpump. I replaced the bypass hose, as well as resealing the gooseneck.
fish56 is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
2003CC
