Spring Spacers
I've done a little research so far and would like to have spring spacers installed for about a 2 inch lift. Are there any kits out there for under $200? I haven't been able to find any for Nissans. Has anyone used these, and if so did you like it? Mine is a 2003.
Thanks, Laura
http://www.myspace.com/LaIraDelChupacabra ![]() 2003 Frontier SE V6 Crew Cab, Flowmaster dual exhaust |
If you are talking about 2" spring spacers in the front to level out your truck, then yes there are some for under $200. They are available from a sponsor of this site, PRG Products:
http://www.prgproducts.com/frontier_components.php
2005 NISMO KC 4X4 - BLK ![]() Current Config: K&N CAI : WRP TBS : Dynomax Dual Exhaust : WRP Intake Manifold Spacer : WRP Crank Pulley : WRP Pwr Steering Pulley : WRP Grounding Kit : 2* Timing Advance : Redline Tuning Hood Struts : Penski Sliders - pilot project(?) : 2.5" PRG-Mini Lift : 2" 4Crawler Body Lift : Titan Bilstein Shocks : Shrockworks Bumper : Ramsey Patriot 9500 UT Winch : PIAA 520 SMR's : BFGoodrich AT's @ 285/75R16 : KMA Multi-Carrier Rear Bumper |
its a first gen dude.
can you clarify a little?
possibly looking for blocks for the rear?
if that's the case and you only want ~2" lift...get some lift shackles from calmini.com
No springs to space in the front of a 1st gen. You need to crank the t-bars.
05 Frontier KC Nismo 4x4. 255/85R16 Maxxis Bighorns, Titan Swap, SAWs w/ PRG UCAs, custom rear springs, PRG shackles, Bil 5125s, U-bolt flip, custom shock mounts, DIY 2" BL, Demello Sliders, Shrockworks Engine, Front/Radiator & Gas Tank skids, 15# Ultimate Air CO2, WRP Crank Pulley and IMS, Fujita Intake, Slotted Rotors/EBC Pads, Braided Brake Lines, WRF Lightbar w/ HID converted Hella 500s. |
its 60 for a single add a leaf form 4x4parts.com
Ok I'm new to all this, but your truck is EXACTLY what I'm looking for as far as lift. I've gotten bigger new nubby tires, and recently a new Flowmaster dual with dump (sounds good, I'm loving the low,low rumble).....So, how do you adjust the torsion springs, etc? Your truck looks SO GOOD!!!! You did a great job.. Laura
Thanks very much Laura
Checkout the sticky thread in this forum 1st Gen FAQ...PLEASE READ. ADD INPUT Scroll down on the first post until you see "LIFT OPTIONS..." and read a bit there, there is also a link to the torsion bar writeup which should help http://www.nissanoffroad.net/how_to/...rsion_bars.asp Keep in mind I also have a 3" body lift, so I'm sitting somewhere around 5 1/2 - 6" of total lift, but there's no way to do that with just the suspension alone. Feel free to let us know if things regarding the torsion bar lift don't make sense. |
