Old 02-09-2007, 12:39 AM
adam42381's Avatar
Spare Keyless Entry Programming?
When I bought my 2001 SE yesterday it came with only one keyless entry keychain. The dealership gave me a second one which was not yet programmed. I need to know how to program it so my wife can use it. I followed these instructions:
1. Programming Procedure:
A. Get in the vehicle. Close and lock all doors using the driver's power door lock-unlock switch.
B. Insert and remove the ignition key more than 6 times within a 10 second period (at a rate of one insertion/removal cycle per second). The key should be withdrawn from the ignition key cylinder completely each time it is removed.
NOTE : Do not rush the insertion/removal key cycling process.
C. Turn the [COLOR=green ! important][COLOR=green ! important]ignition [COLOR=green ! important]key[/color][/color][/color] to the "ACC" position. The ignition key should remain in the "ACC" position throughout the remainder of the programming, including programming of additional remote controllers.
D. Press any button on the remote controller one time.
NOTE : Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful.
The hazard warning lights will flash twice when this step is accurately completed and programming is successful.
E. If you are programming only one remote, proceed to step 3A. If programming additional remotes, continue with step 2A, below.
2. Programming Additional Remote Controllers (Maximum of 4 Remotes):
A. Remain inside the vehicle after programming the first remote.
B. Use the driver's power door lock-unlock switch to unlock and then lock the doors.
C. Press any button on one of the additional remote controllers one time.
The hazard warning lights will flash twice when programming is successful.
If there is more than one additional remote to be programmed, repeat steps 2A through 2C above for each additional remote.
3. End Programming:
A. Remove the key from the ignition.
B. Use the door lock-unlock switch on the driver's door to unlock the doors. Open the driver's door to complete the programming
C. Check the operation of each of the remote controllers by locking/unlocking the doors with each remote controller you have programmed.
The second remote still isn't working. Any suggestions? The dealer basically refused to do it for me without paying them $40.
Old 02-09-2007, 01:59 AM
kris's Avatar
AA. PUSH BRAKE PEDAL DOWN.
Only thing I did differently on mine was push the brake in after the doors locked.
'05 4X4 Storm Gray CC
JBA Cat-Back, Injen Power Flow Intake, Shrockworks sliders, other stuff in the works.
'02 4X4 Super Black Xterra
Nismo CAI, Nismo Cat-Back, Shrockworks skids and sliders.
Old 02-09-2007, 02:57 AM
FindingNismo's Avatar
i did the instructions you posted a while back and it worked perfect. have you checked the battery in the remote fob? maybe its bad. does it even have a battery in it?
2000 SE CC
Old 02-16-2007, 11:14 PM
loaizarayas's Avatar
Send a message via MSN to loaizarayas
this thread should be pin in the DIY section.
does this steps also work in the 2005-06 models?
A lost Stang in a world of Frontiers...
2008 Ford Mustang: Premium Coupe V6, Phony package, and that's about it
