Old 08-07-2008, 07:42 PM
ochsbeatdown's Avatar
Send a message via AIM to ochsbeatdown
she smells like gas!
so more and more i've noticed my truck smelling of gas...no leaks, caps on tight. dad thinks it might be that evaporation canister or something for emissions and i might need a new one? not sure...i get whiffs when i get out of the truck, or if im sitting in traffic and a car passes by me....definitly a bitmore prominent when i first fill up. any ideas?
2001 Nissan Frontier XE 5-spd
-Kenwood KDC MP732 headunit with iPod adapter
-Alpine SPS-17C2 6.5 inch door speakers
Blaupunkt Thb 200A sub
-Truxedo Truxport Tonneau Cover
Rutgers University '09
Old 08-07-2008, 07:47 PM
MORE then likely you have a leak some where and just havent found it yet...,
if it was a evap canister or somthing to that effect with the obdII computers normally throw a code..
see pics of the truck Here
2004 XE 2.4l I-4
part of The Lifted XE Club!
F.W.O West Coast Chapter
MODS: Total Chaos Long Travel Kit, Shock Hoops, Fox 2.5 coil overs w/ eitbach springs, Fiberglass Fenders, Dever progessive add a leafs, Panasonic CQ-C7303U Clarion 4 channel 400W amp pushing a set of JL audio 6.5 Compents, MA Audio 400w 2 channel amp pushing Kicker Comp 10", XM Radio, Magnaflow 2 1/4 in/out dumped before the axle. 5% tint on rear windows 35% on front windows, oval fog lights from kragen.
Soon to be mods:engine brace,
Future mods: Rear Deavers
Old 08-07-2008, 07:58 PM
oh really? hmm yeah she's not throwing any codes....alright hmm, how should i look lol..i haven't found anything yet
Old 08-07-2008, 08:02 PM
start at the gastank and work your way forward, on my camaro (i know i different vehical but works in this case) i was accually doing a tune up on the car (adjusting the carb) and saw a nice stream of gas shooting onto my exaust... needless to say i shat my pants and turned off the car lol.
so just start at one end and work your way to they other...
2004 XE 2.4l I-4
Old 08-07-2008, 08:05 PM
NissanTy's Avatar
could be a loose gas line or a worn gas line and gas evaporates before it hits the ground, also check to see if the fuel filter isn't leaking, i would say also check the gas filler kneck but then it would more than likely throw a code.
Tyler
Old 08-07-2008, 08:15 PM
thanks for the advice guys! ill have to give her a look on my next day off, whenever that is ugh
Old 08-07-2008, 09:10 PM
beefy242's Avatar
so your truck smells expensive then...
seems like there may be a leak involving the exhaust system.
cardomain page:
Old 08-07-2008, 09:28 PM
XE_KING's Avatar
there is a bulletin on this.. it is a anti-flowback valve in the filler neck. check the recalls. its there.. i had it.. and my stealership made me pay for it to be fixed.. but it was cheap...
-Nick-
Old 08-08-2008, 09:14 AM
daves d22u's Avatar
when you get gas does the guy top it of all the way?
might wanna just check the canister. unbolt it take the valve off the front and turn it upside down to see if any fuel comes out of the canister.
sometimes topping off will push fuel into the evap system.
also look at the top of your fuel tank. they like to rot out around the sender.
Old 08-08-2008, 01:29 PM
jerryp58's Avatar
This may be out there, but have you made any changes recently? A guy I work with had a Dodge pickup that did not like the Bosch +4 plugs. As soon as he put them in, he noticed a strong gas odor; I guess the computer was dumping more fuel into the cylinders for some reason. He replaced the plugs and the odor was gone.
Jerry
My Frontier Page
