Old 08-21-2007, 10:18 AM
opie's Avatar
Running 32 x 11.50 tires
What do you guys suggjest i do to run a set of 32 x 11.50 on my 1999 frontier. it has 31 x 10.50 on it now and they don't rub. this is going to be a next summer project and want prep for it now.
Thanks opie
Old 08-21-2007, 05:49 PM
pbh114's Avatar
I run BFG ATs that are 32X11.50R15. I've got a 3 inch body lift and and add a leaf in the back with no rubbing. They would rub pretty bad with a stocker though. Hope that helps
'00 XE CC V6, 3" body lift, Calmini UCA's, add-a-leaf in the rear, bronze Nismo wheels, 285/75R16 Nitto Teragrapplers, AEM Brute Force CAI, Nismo exhaust, ultra low-pro upper UCA bump stops, Bilstein steering stabilizer, AC idler arm brace, AVS Ventshades and Bugflector, Viair 350c air system with 150dB Siege Engineering Hammer 3 Air horn
Old 08-22-2007, 09:40 AM
opie's Avatar
I plan on doing a 2 or 3 inch torsion bar lift in the front and a 2 1/2 to 3 1/2 inch shackel drop for the rear. That should be enough clearnce from what I have read? But does anyone know were i can get a set of lift shackle other then the $13 set at Auto Zone.
Thanks Opie
Old 08-22-2007, 10:03 AM
HarshReality001's Avatar
beefier shackles at www.4x4parts.com and www.purenissan.com
"It's not the triumph, but the struggle..."
CarDomain / Gallery / LINXC
Old 08-22-2007, 05:54 PM
pbh114's Avatar
I think you will be ok, with just some minor rubbing at full tilt if any at all
Old 08-24-2007, 11:52 PM
adorsey's Avatar
Where did you get your body lift? I want a supension lift but I just don't off road and its 2wd so a small body lift would be great but not something noticable if you know what I mean.
2000 KC Desert Runner V6, AAL, Calmini Shackles, Calmini UCA's, Rancho 5000s all around, AC idler arm brace, 31" BFG A/T, K&N CAI, Flowmaster 50 SUV, WRP Grounding Kit, NGK Plugs and Wires, Silverstars, AVS Ventshades, 20% tint, Headunit, 600w amp, 12" sub, Door Speakers
