Originally Posted by Exodus5
It is a V6. I had the timing belt replaced less than a year ago...do they do that when they take the front of the engine off? I'm not really sure what you're referring to as the "gooseneck"...
The "gooseneck" is the thermostat housing. You'll want to unbolt this housing, not just the top part that holds the t-stat but the entire housing. Lift it as high as you can get it. About 1/2". You might have to cut the 90 degree bypass hose to gain access, but since you'll have the intake off you should be OK. Probably a good idea to change this hose while you've got it off. Clean and reseal the gooseneck to the block. I used a quality gasket cement. And no, they wouldn't have touched this when replacing the timing belt and water pump.
