Replacing valve cover/intake gaskets...what else while I'm there? - Nissan Frontier Forum
post #1 of 6 (permalink) Old 11-21-2010, 01:22 PM Thread Starter
So I've got a leaking valve cover gasket. It's allowing oil to drip onto the manifold and smell/smoke a little. I figure If I replace those I might as well do the intake manifold gaskets since I've got to take that off. What else should I check or replace? I know the Knock sensor is a common issue so I'm thinking I'll do that, but is there anything else I need to pay attention to while I'm going to have the intake off? I figure I'll clean it, at least.
Exodus5 is offline
post #2 of 6 (permalink) Old 11-21-2010, 05:47 PM
TwoBills's Avatar
If you've got a v6 I'd reseal the gooseneck housing, where it bolts to the block. It's prone to leak and a bugger to seal from scratch.
TwoBills is offline
post #3 of 6 (permalink) Old 11-22-2010, 11:06 AM
Definitely flush out (or replace) the hose / hard pipe that connects the right side valve cover to the PCV valve. Depending on how much oil is in there, you may want to replace your PCV valve as well.
pennbiker is offline
post #4 of 6 (permalink) Old 11-24-2010, 04:58 PM Thread Starter
It is a V6. I had the timing belt replaced less than a year ago...do they do that when they take the front of the engine off? I'm not really sure what you're referring to as the "gooseneck"...
Exodus5 is offline
post #5 of 6 (permalink) Old 01-08-2011, 11:52 AM
DannyD22's Avatar
Send a message via AIM to DannyD22
I'm replacing both valve cover gaskets today, anything other than checking the pcv hose to look out for?
Traded: '02 Silver Ice CC shortbed XE V6 auto 2wd - Ebay intake, Gibson exhaust, full sound system (///Alpine, JL Audio, MB Quart, Image Dynamics), ebay OEM-style fogs, painted headlight housings, Xentec 6000K hi/lo HID kit, Nokya 2500K H3 fogs, 3" SL (AC 3" AAL, AC front UCA's), custom powdercoated ProComp Stryker 18x9's, Toyo 285/60/18 Open Country AT's, NISMO oil & rad caps.
Gone - '05 350Z 6mt Turbonetics single turbo 400whp/400wtq - R.I.P. 5/23/09
Current: 2012 Genesis Coupe 2.0T R-Spec
DannyD22 is offline
post #6 of 6 (permalink) Old 01-08-2011, 05:10 PM
TwoBills's Avatar
The "gooseneck" is the thermostat housing. You'll want to unbolt this housing, not just the top part that holds the t-stat but the entire housing. Lift it as high as you can get it. About 1/2". You might have to cut the 90 degree bypass hose to gain access, but since you'll have the intake off you should be OK. Probably a good idea to change this hose while you've got it off. Clean and reseal the gooseneck to the block. I used a quality gasket cement. And no, they wouldn't have touched this when replacing the timing belt and water pump.
TwoBills is offline
