has anyone replaced there gauges with aftermarket ones. I want to install all aftermarket gauges. MPH, water temp, volts, ect......
My only question is can you just tap into the stock wiring harness for MPH and stuff??? I found the tach wire and I can do the volts for oil pressur and water temp all that im not sure where to tap into for correct readings. any advice will help. Thanks Guys
