Old 08-14-2008, 10:46 PM
Rattling loose rings under truck! What? See pic...
I noticed a rattle sound while sitting at traffic lights and I noticed two loose metal rings that rattle at low RPM's while in drive. The rings are under the truck and it appears they were holding on a cover, but I do not know to what. What is the exposed mesh cylinder in the photo?
Anyone have any idea what is going on here? Thanks,
2002 Nissan Frontier SE Crew Cab Long Bed 4x4, Roof Rack, Step Bumper, Rockford Fostgate Premium Sound, Keyless Entry, Wolo Bad Boy Horn
Old 08-14-2008, 10:47 PM
Inyourface1650's Avatar
Thats the flex pipe in your exhaust, and I imagine those were holding things together. Which means its time for a new flex pipe
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
ONAZ
Old 08-14-2008, 11:02 PM
Also while you are under there you may want to check your kitties. There are two cats one on each side almost directly under the drivers/riders feet. These heat shield will rust off and start to rattle too. If they have you can just remove them.
Since I have about the same truck you do (mine 2003 CC LB SE), I thought I would mention it.
If those rings are just hanging there cut them off. I'd wait till the the exhaust started to make noisy before taking it in.
2003 silver CC LB V6 SE non-s, leather, e-fan, nismo wheels, sunroof, nerf bars, knock sensor mod, interior courtesy lights, Rockford Fosgate Audio, oem trailer harness, children seats in rear mod.
My Write ups - e-fan, Nismo - CAI,Disable auto AC w/defrost
Old 08-15-2008, 10:45 AM
daves d22u's Avatar
mine rattled 2 yrs ago. cut them off. still no problem.
Old 08-15-2008, 11:00 AM
slow95tsi's Avatar
Very common to see on a Nissan. Like daves d22u said just cut them off or tack weld them back in place.
Old 08-15-2008, 11:33 AM
grantb7machz's Avatar
I just removed the heat shield, from the cat on the drivers side, about 2 weeks ago.
2003 Frontier, 3" body lift, 3" Suspension Lift(Calmini UCAs, Idler Arm Brace and Shocks), add a leaf in the rear. 2" wheel spacers, stock rims, and 33 x 12.5 BFG's. Delta tool box, back rack and 100w hellas. Custom bull bar w/skidplate and painted back bumper. Pioneer Premier 960 head unit with sirius box. Alpine Type R components in the doors, Infinity 6X9's in the rear. 2 Alpine Amps with a cap powering two 12" Alpine Type R Subs and a pioneer amp for the rest.
Old 08-15-2008, 12:24 PM
Send a message via AIM to tsacain
I took those off over 2 years ago and no issue. I also ripped off the heat shield on the driver and passenger side cats too.
Kevin
2002 Silver DR
with a few mods
Old 08-15-2008, 02:49 PM
Yup, it happens to most Nissans. Just take a snips, cut em off, through em away and enjoy the peace and quiet.
Old 08-20-2008, 07:13 PM
XE_KING's Avatar
So I checked my cats today and both of them are rattling inside.. good times.. Hope it passes DEQ then Ill do some highflow cats..
-Nick-
F.W.O West Coast Chapter
