P0442 Great... - Nissan Frontier / Navara Forum
Old 09-23-2007, 01:06 AM
Firelli's Avatar
Unhappy P0442 Great...
Well my check engine light came on. Got it scanned and got the infamous P0328 (Knock Sensor) and P0442 (Small EVAP leak). I checked the gas cap and it was on tight. Anyone else have a similar problem?
2003 XE V6 Frontier: [Current Mods: Nismo Intake+Exhaust+Rims+Shocks, 32" Pirelli Scorpion ATRs, 2" Lift, Manik Brushguard, 3x5 KC HiLites, WT Window Deflectors, 2 Rockford Fosgate P1 Subs + Kenwood Amp]
Old 09-23-2007, 01:20 AM
dcobb's Avatar
I believe the faulty knock sensor is considered a feature with these trucks. he EVAP leak is causing the CEL though
Old 09-23-2007, 11:39 AM
fronty2wd's Avatar
Just crawl under the truck and start at the rear where the evap box is. Check all the lines from the box all the way to the engine. Also check your filler neck for any damage. I had this happen with my bl i just had to resecure the fillerneck extension.
Pretty much stock.
Old 09-24-2007, 10:17 AM
Why dont we call nissan and complain about the knock sensor and gas mileage
if everyone did then maybe we could get em fixed?
Old 09-24-2007, 01:56 PM
dcobb's Avatar
That's a great Idea CRDLIBERTY! You get the ball rolling and I'll gladly add my vote. I have no idea if age is a factor or not but obviously there are a lot of people here reading bad knock sensors and considering it's mostly a silent problem you know a lot more people have issues with them that simply don't know.
Believe it or not When i was investigating this months back I called up a few Nissan service managers and more than one said that many of the frontiers had issues with this, one guy admitted to probably more than half have bad knock sensors. So it's obviously a manufacturing defect or bad sensor placement. I was also told by them that I could probably just let it go or try switching to a higher grade fuel.
If however you do need to get this thing fixed, it's quite involved labor wise and I was quoted something like 6-8 hours. Nissan would take a huge $$ hit to recall this, so sadly I don't see anything coming out of it, but don't let that stop you from trying
Old 09-24-2007, 03:58 PM
silversuper's Avatar
yea mine had that knock code 20 thou miles ago, still runs good
Richie, i love mozilla
www.linxc.com
2001 silver SC CC
Old 09-24-2007, 04:34 PM
dcobb's Avatar
It was told to me that it retards timing in situations where it detects knocks, and that knocks usually occur when hitting the peddle hard, climbing a steep grade or towing something heavy, basically putting a lot of strain on the engine. However I've towed heavy loads and never had a problem. So even in situations where it might be a factor I've not had any issues with knocking and I use 87 octane as well, so go figure. So long as it doesn't pose a real threat I'll never fix it.
Old 09-24-2007, 06:06 PM
Firelli's Avatar
Yes a lot of the knock sensors on Frontiers/Xterras are bad. You won't even realize it because it won't light up the MIL.
Anyways I looked at the EVAP lines and I can't find anything. There are tests I can do but it requires a special pump and leak detectors and I don't have those. I've heard you can smoke test it but I don't have that equipment either. It doesn't effect the engine and I don't have to worry about emissions so I guess I'm stuck with the MIL on.
Old 10-12-2007, 12:26 AM
I know i'm kinda late on the info here.. But this is a very common thing.
I think its more common with the S/C models, mainly because the requirement for premium fuel.
I have a S/C model, and anytime i have regular unleaded put in the truck (by accident, full service idiot, or wife) I get the knock sensor, and sometimes EVAP also... I run some Chevron Techtron through it, and a few miles later, its gone... The one time i got the EVAP, i stopped into AutoZone... they wouldn't clear it, but read it and let me use there set up to clear my code... and its gone...
Usually the cause of this will be due to recent fill up, and gas octain wasn't up to par.. Or... if you run really low on gas and cause it to suck up some junk...
Nothing to worry about though... defanately normal to say the least...
Old 10-12-2007, 11:35 AM
The evap charcoal
On BMWs i know for a fact it states not to overfill your tank because the charcoal canister fills with gas then the codes come and a little less gas mileage. First click and thats it
