Oops broke a wire at the distributor ! Pics inside - Nissan Frontier / Navara Forum
Old 11-10-2012, 10:56 PM
Joosty's Avatar
So I'm changing the timing belt and I start pulling hoses etc.
Then I notice this wire has disconnected from its source . All I know is it goes into the distributor and has a pigtail connection .
Any ideas ? Am I SOL and have to get a new distributor ?
Pic is in the link below
http://imageshack.us/a/img29/3066/imagegne.jpg
2001 Gold Rush Metallic SE Crew Cab 4X4 5 Speed
361K+ and counting original owner and engine.
Old 11-11-2012, 08:53 AM
speedfoos's Avatar
Ooof. I would try to carefully cut that rubber back and re-solder it before dropping a couple bennies on a new distributor.
Manual Swap'd
| PHOTOS | TWO WHEELS | FOUR WHEELS |
The Following User Says Thank You to speedfoos For This Useful Post:
Joosty (11-13-2012)
Old 11-11-2012, 10:41 AM
Hertz's Avatar
I would try to wire up a new plug.
The Following User Says Thank You to Hertz For This Useful Post:
Joosty (11-13-2012)
Old 11-11-2012, 11:04 AM
Cusser's Avatar
That's exactly what I did with a similar happening on my old Mazda truck. It turned out on mine that the "thing" was simply a radio static suppressor. Have you identified what that is on yours?
The Following User Says Thank You to Cusser For This Useful Post:
Joosty (11-13-2012)
Old 11-13-2012, 10:46 PM
Joosty's Avatar
Thanks for the responses guys. I might just have to re solder it or something
All I know is its apart of the distributor and I've seen pics of new distributors with this wire connected to the actual system .
In for more replies
Old 11-14-2012, 01:20 AM
Jrjones's Avatar
Just take the cap off and either solder it or re-wire it with a new wire, pin (for the connector), and blade terminal.
Don't need to cut any rubber anywhere (which could compromise the waterproofness of the distributor and lead to failure)
Old 11-14-2012, 03:37 PM
I'm fairly certain that is what that part does, eliminates electrical "noise". The D-21s had them on the wiring to the alternator, I broke one once and used a part out of a chevy points rebuild kit to replace it.
Old 11-14-2012, 10:12 PM
Joosty's Avatar
Thanks for all the repsonses. You guys are all cool
