Oil Leak.. - Nissan Frontier Forum
post #1 of 11 (permalink) Old 02-24-2011, 04:59 PM Thread Starter
Oil Leak..
Ok, so I have a small oil leak. It has been leaking for about 6 months now, and I just can't take it..It is all underneath around the oil pan, up on the passenger side of the engine and on my driveway. I am looking to fix the leak or leaks, but I am not sure the best way to troubleshoot this. I was told once that I could pressure wash the engine and place cardboard underneath (after it dries) and help determine the leak. Or just start with the oil pan seal and clean up around there. I had a '93 Sentra before this '01 Frontier, and it had the same issue (I replaced the oil pan gasket and it was good after that). It does not leak enough where I need to add any oil though (cold or hot measurements). Anyone share their thoughts/suggestions? The smell of burnt oil is not fun..
kalan_vod is offline
post #2 of 11 (permalink) Old 02-24-2011, 05:51 PM
Jeremy0966's Avatar
Send a message via Yahoo to Jeremy0966
It could be your rear main seal or the oil pressure switch. The problem being its been leaking for months so as you drive oil is thrown all over the place making it hard to determine were the leak or leaks are comin from. Id take a degreaser to bottom and clean it as best as possible drive it around the block just enough to let it warm up then park it over some cardboard. Any fresh oil or leaks should be relatively easy to spot.
Jeremy0966 is offline
post #3 of 11 (permalink) Old 02-24-2011, 07:44 PM
Zero Six LE's Avatar
Quoted: 832 Post(s)
I would suspect the engine oil pressure sending unit. It could be leaking from the threaded area or the body where the plastic is joined to the metal.
Zero Six LE is offline
post #4 of 11 (permalink) Old 02-24-2011, 08:37 PM
Mathster's Avatar
Quoted: 94 Post(s)
since the oil is around the oil pan, I would say probably front main seal.
The rear would be around the transmission and back of engine.
How many miles? Mine started leaking around 130K
13CC4x4SV
Mathster is offline
post #5 of 11 (permalink) Old 02-24-2011, 08:54 PM Thread Starter
Thanks guys, I will give the degreaser a try on the next dry day we have. My truck is at 133k, which I guess it started around 130 as yours did.
post #6 of 11 (permalink) Old 02-28-2011, 10:23 AM
Oil pressure sensor is on the driver's side above the oil filter. Doubt that's the issue. If you're really smelling "burnt" oil, I would look above the exhaust manifold at the valve cover.
pennbiker is offline
post #7 of 11 (permalink) Old 02-28-2011, 03:47 PM
Agree with Pennbiker. Check the valve cover. The pass side one is a lot easier to get to than the driver side. Try to cinch up the cover bolts a little.
Are you sure it's engine oil? The power steering tank and pump are up high on that side and a leak up there could be blowing back onto the manifold as you go down the road.
perry1 is offline
post #8 of 11 (permalink) Old 02-28-2011, 04:12 PM Thread Starter
I just looked exactly where you said, and I see oil on both sides...Pictures were taken with my phone, more noticeable in person.
post #9 of 11 (permalink) Old 02-28-2011, 07:21 PM
Quoted: 832 Post(s)
Those are way overdue for replacement. They are hard and brittle. I recently replaced some on my friend's 02 Frontier with a little over 70,000 miles on it.
post #10 of 11 (permalink) Old 03-01-2011, 12:04 PM Thread Starter
Both manifold gaskets? As far as I know, no seal/gaskets have been replaced and it is at 132k..Anyone want to point me in the right direction?
