Misfire in cylinder #6 - Page 2 - Nissan Frontier Forum
post #11 of 18 (permalink) Old 06-29-2010, 03:21 PM
rcr_kx250f's Avatar
What's the resistance on the plug wire for 6? Also compare it with others, could be a "new" plug wire that's going bad.
I work on the dark side. Diesels rule.
rcr_kx250f is offline
post #12 of 18 (permalink) Old 06-29-2010, 03:23 PM
Whiffle's Avatar
Or swap plug wires with another cylinder of the same length and see if the misfire moves.
"You can't be a real country unless you have a beer and an airline - it helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer."
-Frank Zappa
2007 2WD 6 speed Frontier SE CCLB
Whiffle is offline
post #13 of 18 (permalink) Old 06-29-2010, 03:58 PM Thread Starter
Checked the resistance of the old wire was running at 7.8k ohm, the service manual specifies 11k ohm. The new wire is running at 10.8k ohm, which is far better than the old wire but did not cure my misfire problem unfortunately.
4x4Safari is offline
post #14 of 18 (permalink) Old 06-29-2010, 08:50 PM
TwoBills's Avatar
Could the problem be battery or ground related? Just thought I'd throw that out there.
TwoBills is offline
post #15 of 18 (permalink) Old 06-30-2010, 11:58 AM
Sartor's Avatar
Originally Posted by 4x4Safari View Post
Frustrated and annoyed I spent more time last night diagnosing my problem. I did manage to get a stethoscope up on injector #6 and what would you know the injector is ticking like a time bomb. So I guess I ruled out another problem area it does not appear to be the injector.
I then noticed a small 5mm vacuum line at the back of the intake manifold that was ported into the runner tube for cylinder #6 and immediately thought this could be my problem all along. An air leak unique to cylinder #6 I promptly pulled the hose and plugged the port. My excitement was short lived no change.
After all the diagnostics I have performed I sat down and tried to record the exact moments the issue occurs, I noticed a pattern if anyone can shed more light I would appreciate it.
1) The rough idle and stumbling only appears to happen after a long period of sitting with the engine off, for example over night in my garage. When I first start the truck up in the morning and allow it to idle the engine stumbles and runs rough and then throws the misfire code, engine check light is on. However if I clear the light and start the engine cold and then pop the gas 2 or 3 times racing the engine to 3000rpm and then letting it idle again the engine does not stumble and does not throw the code.
2) Second it appears that the code is only thrown when at cold start if I drive the truck stop start though the day on and off, only stopping for an hour or so I don’t get the code.
Something appears to be happening while it is standing for long periods, fuel pressure and drain down does come to mind. Either pump or fuel pressure regulator, however I would expect a more random misfire and again its always on #6.
The investigation continues.
how many miles does the truck have on it? cylinder # 6 may not be getting oiled properly... causing the piston stroke to act slightly different. might be a good idea to check your oil journals and/or oil level.
Sartor is offline
post #16 of 18 (permalink) Old 07-20-2010, 07:01 PM Thread Starter
Finally solved the mystery, after weeks of diagnosis which I am glad I did instead of throwing money at the problem.
I ended up loaning a Radiator leak test kit from a parts store and performed a leak test on the cooling system. Well no immediate visual leaks and the pressure remained pretty constant. I left it to sit for about 30 minutes and noticed the pressure had dropped slightly, the longer I left it the more it dropped. I had found a small leak in the cooling system, the question was where?
No visual leaks at all on the outside of the engine, and the fact that the engine idled rough meant it was leaking into the cylinder. This would mean either the head gasket or the intake plenum gasket had failed. The fact that I had consistent cylinder #6 misfire and nothing else would say it could be the intake intake plenum. A quick compression test between cylinder #6 and the adjacent cylinder I think #4 confirmed no leaks between the two cylinders. The compression test also showed as before that the pressure was within manufacturing specifications. This meant the intake plenum was definitely the culprit here.
Also check the codes again and I picked up a new misfire on cylinder #5 which is on the opposite bank to cylinder #6 which definitely confirms unless I have both head gaskets blown the coolant passage between #5 and #6 is leaking in the intake plenum. This is causing the misfire code and the rough idling as the engine tries to burn the coolant, this also explains why it was rough at start but disappeared after a few seconds. Once the coolant that has pooled in the cylinder from standing has been burned up the engine performs normally.
Good excuse to fix my knock sensor while i am down there, well I will update all on the progress once I have replaced the gaskets. Thanks to everyone for input on the topic and again it pays to diagnose the hell of a problem before throwing money at it. I am planning on documenting the repair with detailed pictures, as I have noticed many people on the forum requesting information on knock sensor replacement.
post #17 of 18 (permalink) Old 07-21-2010, 05:26 AM
glad you figured out the prob.
99 frontier xe
99.5 Maxima SE-L
1fstmax is offline
post #18 of 18 (permalink) Old 01-21-2013, 08:26 PM
Did replacing the gaskets solve the problem? I'm having the exact same problem and don't want to start blind.
ebenner2 is offline
