Loss of power, need help please - Nissan Frontier Forum
post #1 of 22 (permalink) Old 08-07-2009, 11:18 AM Thread Starter
I have a 2001 S/C Frontier with 65K miles on it and here is my issue.... When the truck is cold, it's a beast, runs awesome, instant acceleration, I can spin the tires, it performs great. When it warms up, it loses power from a stand still in drive, off the line. It's a dog, no power until it gets up to speed. I also have noticed a very mild skip in the engine, at a stop in drive.
Here is what I have done so far (all have been present before the knock sensor relocation, I have no codes at all, no SEL also):
new fuel filter
cleaned the throttle body
new rotor and cap
cleaned the MAFS
new PCV
pulled a plug, it looks great, plugs are 1 year old 10K miles on them
tried two different fuel injection cleaners, two full tanks of fuel
checked for vacuum leaks, (I sprayed carb cleaner) lines look good cleaned my air filter (K&N)
battery pull
Wires look great
I noticed the following....If I'm driving and the truck is acting like a dog (powerless) from a dead stop and I pull over to the side of the road, shut the truck off, restart it, my first launch from a dead stop after shutting the truck off is where the truck should be, power and performance is there. As soon as I pull up to the next stop sign, come to a complete stop, she's a dog again. I did this 5 times and all five times the truck acted exactly the same: complete stop, shut it off, power, at the next next stop no power.
I've changed the knock sensor. The fuel tank was changed about 3 years ago due to extensive corrosion caused by the Nissan fuel pump recall campaign.
So to recap, truck runs awesome, COLD, as soon as she heats up, no performance launching from a dead stop.
When the truck is warm, and I pull over, shut it off, re-start it and launch, runs great for that first launch, consistently, then back to being a dog. On the highway it performs well, and under aggressive acceleration she doesn't sputter or bog down.
Any more help would be greatly appreciated
What am I missing?
GothamEMS is offline
post #2 of 22 (permalink) Old 08-07-2009, 01:19 PM
RockHawk JHKU's Avatar
I'll be the first to admit that I have very little experience working with engines, but two things came to mind. Based on what you've tried so far, I'm guessing you know more about powertrains than I do, but can't hurt to throw out ideas, so here it goes:
First thing that came to mind was wondering if you had done anything with your ECU? Any re-programing or anything like that? If so, might not hurt to try resetting to stock and see what happens.
Second thing that came to mind was some kind of exhaust issue. ie maybe your cats are bogging down, but that doesn't really fit with strong performance at highway speeds after warming up. But it does work with why the first launch after you shut it off is fine (ie time for the cats to dump their back pressure).
Avalanche 09 CC SE 4x4
Current Mods: BakFlip G2 tonneau, Aries nerfs, JVC HD Radio head unit, PIAA Xtreme White Plus
Planned Mods: leather seats, Wabasto power sunroof, Kenwood speakers, ambient lighting, bull bar, fogs, trailer hitch, 3" suspension lift, 18" wheels and larger AT tires
Wishful thinking (want, but would be very long term): replace the hard gray plastic interior, HIDs, CAI, superchip, change the dash illumuination to blue or red
RockHawk JHKU is offline
post #3 of 22 (permalink) Old 08-07-2009, 01:28 PM
dubie2003's Avatar
Quoted: 10 Post(s)
Did you just recently change the KS? It may be bad again if you did not just change it recently. Also, you may want to install a boost gauge. It sounds as if you are not getting boost. This could be a couple of things but the gauge is your first thing you should do. Without it, you won't know for sure if you have boost or not.
07 SE CC Auto
dubie2003 is offline
post #4 of 22 (permalink) Old 08-07-2009, 03:28 PM
fronty2wd's Avatar
Could be a couple of things. Did you properly torque the knock sensor when you installed it, if not replace it again and properly torque it. Also what are your engine temps? Just because the gauge reads good doesn't mean it is there is a slight amount of deviation aloud by the ecu so that the gauge doesn't constantly flutter... you could be at the top end of it's allowance and the ecu pulls ignition timing and creats a loss in power. Also check your base timing with a light and make sure it's dead on. Also check the wastegate actuator and make sure it isn't sticking and that it's vacuume supply is good and therese no kinks.
Pretty much stock.
fronty2wd is offline
post #5 of 22 (permalink) Old 08-07-2009, 04:01 PM
03CrewSC's Avatar
Quoted: 3 Post(s)
Sounds like you're experiencing 'boost-drop'. When the ECU detects detonation, it deactivates the boost soleniod to bleed off boost and cuts timing to keep damage from occuring to your engine. The only way to reset it is to shut off the engine and restart. I would check the codes to see if your getting a knock sensor code.
My 03 does the same thing in hot weather. It's like a different truck when it is cool outside. I am going to do the knock sensor relocation to see if it helps with mine.
2003 Crew Cab S/C 4x2, Sand Dune
03CrewSC is offline
post #6 of 22 (permalink) Old 08-07-2009, 08:39 PM Thread Starter
I did the knock sensor relocation, I posted a supercharged relocation on this forum, and my truck did have a knock sensor code present when the ECM is read. I have scanned my ECM on three separate occasions, using three separate scanners, and it reads no codes.
I checked all the vacuum lines running to the BVA on the supercharger, all seems good. When at idle, the BVA keeps the bypass valve open, if I hit the throttle, the bypass valve closes, so I don't think it's a BVA issue. I'm stumped, I'm gonna change the wires this weekend. Do you think that the boost senenoid is causing this?
post #7 of 22 (permalink) Old 08-07-2009, 09:48 PM
TwoBills's Avatar
I'd say you've got a leaky BVA. Put a vacuum pump on it and see if it holds vacuum.
I eliminated my BVA and installed a manual cable in it's place. Boost trigger on the shifter. My best mod.
Bump the base timing up a degree or 2.
Get a boost/vacuum guage.
TwoBills is offline
post #8 of 22 (permalink) Old 08-07-2009, 10:24 PM Thread Starter
How did you know your BVA was bad? Was your truck performing similar to mine? Did you have a vacuum issue? The valve is only $46 to replace.
I HAVE FOUND THE PROBELM!!!!!!!!!!!!!!!!!!!!!!
Apparently for some reason, AFTER the knock sensor relocation, and everything I have done to rectify it, with the truck throwing NO CODES, it's running in "fail safe mode"!
Every time the ignition is shut off, the solenoid which controls the S/C BAV, is reset. For this reason, the truck has balls when it's cold, and every time I stopped, shut the truck off, and restarted it. For whatever reason, when the truck warms up, the ECM puts the S/C into bypass mode, controlling the BAV solenoid. If your BAV is located in the 12 O'clock position, the S/C is creating boost and everything is working correctly. When the BAV is in the 9 O'clock position, your S/C is in fail safe mode. To prove this theory, I removed the vacuum line which pulls the BAV to the 9 O/clock position and plugged by inserting a wire nut. With the truck warmed up, and the mode fail safe bypassed, THE TRUCK HAS HUGE BALLZZZZZ, it's like driving a different truck. Now my question is......what is throwing my truck into fail safe mode, bypassing the S/C after all of the following that I've done:
new fuel filter
cleaned throttle body
new rotor and cap
cleaned the MAFS
new PCV
checked for vacuum leaks, none found
battery pull
Wires look great
I know I'm not the only one with this problem, and I will be dammed if I'm gonna let someone else go through what I have with this truck!
post #9 of 22 (permalink) Old 08-08-2009, 06:45 PM
TwoBills's Avatar
new fuel filter
new rotor and cap
cleaned the MAFS
new PCV
battery pull
Wires look great
I had the same symptoms. Boost when cold, nothing when it warmed up. When I lost my boost I noticed a small loss of vacuum. I could see this on my boost/vacuum guage.
When I pulled my blower to get at the gooseneck (long story, do a search of my posts) I stuck a vacuum pump on the BAV. Found that it wouldn't hold pressure. $10 manual cable took the BAV and the computer out of the loop.
I'm still setting 0328 (some years now) and one day I'll get around to checking advance curve. But for now I'm keeping up w/traffic and pulling strong in 3rd and 4th, so I'm not too worried about it. Worst it could do is keep my timing back, so I'm sure not going to have spark knock, but as long as it runs good, who cares.
TwoBills is offline
post #10 of 22 (permalink) Old 08-08-2009, 06:54 PM
joefrontier2's Avatar
Quoted: 21 Post(s)
Did you pull the battery or have the codes reset? Cause the override will stay in there till the ECM is cleared (I think)
Good Links -
Factory Service Manuals
joefrontier2 is offline
