Old 09-06-2007, 12:22 AM
Inyourface1650's Avatar
Originally Posted by Icarus03
Mine takes a few minutes to get cold too, with recirc deselected (fresh air). But it also may be because I live in hot *** Florida where the highs have been in the mid-90's, and the interior of a sealed truck rises to at least 120-130 degrees after a few hours on a sunny day.
Lol, try 115 ambient, and 180F interior temps over here in AZ....and my 02CC still got cold within a minute.
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
ONAZ
Old 05-30-2008, 01:15 PM
kor0000's Avatar
Although I can't say for certain, this does sound like your lack of cold air could be due to the Thermo Control Amplifier (TCA). I haven't replaced mine in 2004 Frontier but I have replaced it in a 2000 Xterra.
One of the symptoms in the Xterra was that it would blow out hot air (yes all the settings were set for cold air for you guys who have issues with setings). Then sometimes it would blow cold and sometimes not.
I checked refrigerant, it was OK. I checked compressor, it engaged properly.
So I got online and found this Thermo Control Amplifier that everyone was talking about.
Picked one up for about 30$.
I replaced it and the owner said the air had never been so cold before. I don't know about just disconnecting it and letting it be; may work, may not, I have no clue.
So where is it?
The TCA is located behind the glove box. Once the glove box is removed the blower motor appears close to the passenger side wall. It is a cylindrical object. Moving toward the driver side, there is a small black box and then a large black box. The TCA is indside this large black box. There should be a red wire and a white wire visible on the outside of this box. These wires go to the thermo control amplifier.
The screws on the back side of the black box are difficult to remove. What I did was remover just enough to be able to pull out the old TCA and then I inserted the new one with a pair of long needle nose pliers. Be sure to remove enough screws, the plastic this box is made from will crack if you try to pry it apart too far. A protrusion on the TCA is inserted into the fins of radiator-type device inside the black box so you need to be able to have a bit of leverage when inserting the new one into the fins and it's difficult to get a hand inside the box.
If it takes 10 minutes to get cold somethings not quite right.
Old 05-30-2008, 01:25 PM
06blackse's Avatar
Originally Posted by Icarus03 View Post
Well, there's your problem right there...the last two words in your post, lol.
Current Collection:
06 Honda Civic EX (SI swap w/turbo, wifes car)
06 Nissan Frontier SE King Cab
(3" PRG, Pro comp 8089 Wheels, Procomp Extreme Mud Terrains 285/75/16, AFE Stage 2 Intake system...Future mods to include: Banks Monster Exhaust system, Superchips tuner, TB spacer)
Old 05-30-2008, 01:50 PM
XE_KING's Avatar
Originally Posted by CRDLIBERTY View Post
A thermo control amplifier behind the glove box has fixed some rigs. The air was just serviced by the guy i bought it from at jiffy lube.
You had better hurry up and tear you oil pan off and clean the sludge out that is from the pennsoil.... wow the one place I would never let touch my truck... Oil change shops a BAD NEWS!! lol. They do everything half a$$ed and charge an arm and a leg for their bad work... at least some of them use better oil...
-Nick-
F.W.O West Coast Chapter
Old 05-30-2008, 04:00 PM
BRUTAL's Avatar
YEAH, I WOULD SAY YOU HAVE A LEAK, HE CHARGED IT UP AND NEVER FIXED THE LEAK, NOW YOU DONT HAVE A GOOD FREON CHARGE LEFT
Old 05-30-2008, 04:54 PM
adorsey's Avatar
It doesn't take mine long at all to get cold. When I took my truck for the test drive I had the same problem and I told the dealer and they did something and he said a hose was loose. Check all your connections and go from there!
2000 KC Desert Runner V6, AAL, Calmini Shackles, Calmini UCA's, Rancho 5000s all around, Bilstein Steering Stabilizer, AC idler arm brace, 31" BFG A/T, K&N CAI,
Flowmaster 50 SUV,WRP Grounding Kit, NGK Plugs and Wires, Silverstars, AVS Ventshades, 20% tint, Headunit, 600w amp, 12" sub, Door Speakers
Old 05-30-2008, 05:15 PM
Hertz's Avatar
Originally Posted by roastbeef View Post
it takes a while for my first gen's air to get cold. about 10 minutes of driving before it starts to cool down. freeway driving is required for it to get cold cold. sucks, but i don't even blow it that often.
sounds like you have a problem too roastbeef :-p.
Old 05-30-2008, 05:25 PM
XE_KING's Avatar
I would get it in to a shop and have them do a pressure test on it. Shouldnt be expensive and will save you in the long run. If he filled it before you bought it he may have either over filled it and blown a o ring(which is common and can be fixed cheap) or didnt use oil too(which needs to be replaced when you charge a system). Just hope that your compressor is not shot. On the up-side, If it is shot you could always just rip it out of your truck and gain Hp and MPG!! then you would have to roll with the windows down all the time though!
-Nick-
