right, well usually the "rule of thumb" is if it has several major cracks in it per inch, it's time to replace or if you see any spots that are worn flat (which may be your case since it's been squeeking). but it sounds like it's just a little loose, might need a new tensioner. if it was the belt i'd do it other times other than just when the a/c is turned on
Patrick // 06 KC Nism osis 6 spd Storm Gray
Mods: lots... Uprev tuned: 244whp & 273 ft lbs
Member of the Canon 5DMkII & 7D Crew, Canon L-glass wh0re
"I prefer to drive manuals because I prefer to drive, not be driven."
