Help! SES code P1126 - Nissan Frontier Forum
post #1 of 20 (permalink) Old 01-06-2010, 05:09 PM Thread Starter
telemike's Avatar
My SES threw a code P1126
Electric Throttle control motor relay circuit open
I cannot find any relay that says throttle control....
Any ideas??????
telemike is offline
post #2 of 20 (permalink) Old 01-06-2010, 07:54 PM Thread Starter
telemike's Avatar
Could it be a bad thermostat?
telemike is offline
post #3 of 20 (permalink) Old 01-06-2010, 08:21 PM
smizwhiz's Avatar
The 2001 Factory Service Manual says it's Thermostat Function - that the thermostat is stuck closed.
2008 Frontier LE Crew Cab Long Bed 4x4
UWS TBS-63-SL Truck Box
Performance Bike Xport Bike Rack
EZ Down Tailgate Assist - failed after 2.5 years
Scosche passPORT 4th Gen iPod Nano charging adapter
smizwhiz is offline
post #4 of 20 (permalink) Old 01-06-2010, 08:29 PM
dublduty's Avatar
Thermostat
Are you leaking or can you smell coolant near the thermostat? If I were you I would just change it out for the cost of one. Make sure you do the gasket as well. Good luck
dublduty is offline
post #5 of 20 (permalink) Old 01-06-2010, 08:33 PM
joefrontier2's Avatar
Quoted: 21 Post(s)
Could it be the temp sensor. What sensor would know that the thermostat is open or closed when it's not suppose to be?
Cause a closed thermostat would cause the engine to overheat and you don't get a light for that? You have a gauge.
scratching my head. I should look this up.
Good Links -
Factory Service Manuals
joefrontier2 is offline
post #6 of 20 (permalink) Old 01-06-2010, 08:47 PM
smizwhiz's Avatar
I mis-read the FSM - thermostat stuck open.
From the FSM -
Malfunction is detected when the engine coolant temperature does not reach the specified temperature even though the engine has run long enough.
This is due to a leak in the seal or the thermosat stuck open.
smizwhiz is offline
post #7 of 20 (permalink) Old 01-06-2010, 09:37 PM Thread Starter
telemike's Avatar
Hmmm.......temp gauge reads about the middle when warmed up and the heater works good. Temp sensor or thermostat? Where is the sensor at?
telemike is offline
post #8 of 20 (permalink) Old 01-06-2010, 10:41 PM
Quoted: 21 Post(s)
How many miles on the coolant and thermostat?
Good Links -
post #9 of 20 (permalink) Old 01-07-2010, 06:34 AM Thread Starter
telemike's Avatar
Coolant is new, thermostat no clue.
20 degrees F this morning. Truck warmed up to normal temp (just about 1/2 way on temp gauge) within about 3-4 miles. That seems normal to me and that the thermostat is working, no?
I'm gonna see if I can bum a garage space to change out the thermostat soon. Do you think it may be the sensor instead?
telemike is offline
post #10 of 20 (permalink) Old 01-07-2010, 08:29 AM
Quoted: 21 Post(s)
Could be the sensor but if you are not sure about the age of the thermostat you should get it changed. Nissan recommends changing it when change your timing belt which is at 105,000 miles. Thermostat is a cheap change for first check.
Your needle seems to be correct but it still could be open a bit.
Get some high temp RTV seal as there is no gasket. At least on my 2003 it's that way. The RTV seal stuff is awsome.
Good Links -
